View Full Version : OHV idle speed.
sumf
07-21-2007, 03:07 AM
The Commander (1964) engine is hunting at idle, at a frequency of about 1 to 2 seconds.
[Fifty years ago my (Navy) EN3 training book suggested changing the oil in the governor. I dare not do that - Arnie could beat the living crap out of me with just his eyelashes!]
Soooo, anyone got any ideas?
Karl
chocolate turkey
07-21-2007, 09:59 AM
Might check for a vacuum leak at the intake manifold. Seen that a couple times on those engines. The carburetor is a known source of trouble on those as well. K.I.S.S. and check the basics first.
Brian K. Curtis
r1lark
07-21-2007, 10:07 AM
Karl
I second what Brian said.
Have you hooked up a vacuum gauge to see what that may tell you?
Is the mixture adjusted correctly? Have you adjusted the valves lately?
My experience has been that these carbs only go about 6 to 7 years between 'rebuilds'. The metering rod diaphragm on mine is usually bad after this amount of time. My '64 Commander OHV 6 is due for a carb kit now.
Paul
Visit The Studebaker Skytop Registry website at: http://hometown.aol.com/r1skytop/myhomepage/index.html
sumf
07-21-2007, 09:07 PM
I timed it through ten cycles, which took about 13 / 14 seonds.
The problem occurs only when hot, so that indicates that it is probably a vacuum leak. Will apply a wrench to the intake manifold when I get a chance to do so. (It's great living in a condo.
I'll get back with the results.
Thanks to all who responded via the forum or directly.
Karl
