View Full Version : weep hole function on a water pump ????
bradnree
07-19-2007, 11:07 PM
What is the function of a weep hole ??.........brad
gordr
07-19-2007, 11:49 PM
To weep, of course.
Seriously, it is to prevent any leakage past the mechanical seal from getting into the bearing assembly and destroying the bearings.
If the seal has failed to the point that you notice leakage from the weep hole, it's time to replace/rebuild the water pump. So think of it as a failure indicator.
JDP
07-19-2007, 11:52 PM
Weeping a few drops a day is normal as is some rust streaking.
JDP/Maryland
64 Daytona HT/R2 clone
64 GT R2
63 GT R2
63 Lark 2 door
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
53k
07-20-2007, 09:16 AM
Make absolutely sure the weep hole is straight down when a water pump is installed. You would be surprised how easy it is to forget that.
Museum R-4 engine
bradnree
07-20-2007, 01:12 PM
Thank you for that trouble shooting tip.......Brad
JDP/Maryland
64 GT R2
63 GT R2
63 Lark 2 door
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
