View Full Version : Distributor problems on 1930's cars after winter s
go-studebaker
07-19-2007, 08:32 AM
Hi guys,
I went to get my 1937 Studebaker out f the shed yesterday. It was parked in November for the winter.
It would not start once I connected the battery up and started crancking because it was not getting a spark.
I just cleaned the contacts for the distributor wire and put a little sandpaper between the points, and it did start fine after that.
Is this a normal thing to do to the 1930's cars ??
Also, the clatch was stuck too. Is there a simple remidy either to prevent this or to check and fix it before I begin cranking ??
Pardon my ignorance here, but although my car is restored I am not quite up to speed for laying cars up for the winter, because in Australia there is no need to.
Thanks
Greg
Greg Diffen
Australian Stude nut living in Warwick, United Kingdom
1933 St Regis Brougham Model 56 Dutch delivered
1937 Dicator sedan. Australian Body by TJ Richards
1939 Packard Seven Passenger monster UK delivered
1939 Commander Sedan Australian Body by TJ Richards
1939 Commander Swiss Cabriolet by Lagenthal
1961 Hawk
1963 Daytona Hardtop
1988 Avanti Convertible
JDP
07-19-2007, 11:01 AM
Points will typically corrode after a few months and the clutch may stick too. If you can start the car and drive until it warms up once a month even in the winter you'll have less work in the spring.
JDP/Maryland
64 Daytona HT/R2 clone
64 GT R2
63 GT R2
63 Lark 2 door
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
dictator27
07-19-2007, 12:21 PM
Speaking as someone who lives on the Wet Coast of Canada, corroded points and sticking clutches are not uncommon here. A quick pass throught the points with a business card might be all that's needed to get the juice flowing. Failing that, beg, borrow or steal your wife's/girfriend's emery board and do the same. I would not recommend sandpaper because sand grains conduct electricity and can set up a bit of a light show inside the distributor. As to the clutch, block the pedal part way down so there is no pressure on the disc, allowing it to "float" between the flywheel and pressure plate.
Terry
