I am about to take on a major undertaking with my rear axle. Have never taken an axle apart and in general have very little mechanical experience. So I'm feeling very apprehensive about this diagnostic search for the problem. and really worried that I may be opening a can of worms. If I can't get it back together, well ....... you know the rest of the story!
Non of our local mechanics are interested in working on a 60 year old car let alone a Studebaker. So, I'm out here on my own.
I am getting a clunking noise at slower speeds and I had thought it was a centre shaft bearing issue. However, with the car up on jacks, and rocking the right rear wheel back and forth, I can hear a clunking sound of a loose metal object coming from the hub area.
Before I start ripping her apart, a few questions that may help relieve the apprehension.
I have searched youtube for any instructional videos on this issue, but it appears there are none. Darn!!!
A while back an old timer came around to install new brake shoes. I did not have a hub puller at that time, so he proceeded to apply high heat to the axle (or hub, can't remember) and then bang on the rear edge of the hub till it finally popped off. My first question. Is it possible or likely that while trying to free the hub, that the axle was "un-set" from the differential? This came to mind after having read the thread yesterday about loose end play in an axle by t1003nl. If so, could the problem be resolved by attempting to simply "re-set" the axle by tapping or driving it back into place?
Looking at the exploded view diagram in the manual, it is very difficult to really see how things work, so I'm thinking I should take the rear cover plate off the differential and have a good study the working parts. Would this be a good idea or not? I am looking at "page 11 REAR AXLE" of the manual. The exploded view shows only the right axle. Why haven't they illustrated the left axle? Also, I don't understand how the adjusting shims play into the picture and what their function is? Does the "lock pin" hold the "thrust block" in place and is the pin an essential part? (I have read stories about the pin becoming dislodged or even lost).
If anyone has any suggestions as to how I should tackle this or what the possible problem could be, I'd love to hear from you. I know there is a great resource of technical knowledge out there and I worry that as we all get older and move on to distant places, that this knowledge will be lost for good. I'd love to see more instructional videos on-line. If you know of any that I may have missed could you please drop a link in a reply to this thread. Thanks!
