So in my 62 gt hawk I am having a problem where the passenger seat just wants to sit in recline, and will not sit up, in fact it wont go forward at all, so I have the side mechanism apart and it seems to be an issue with the middle pivit and probably needs replacing. Does anybody know where I can find peices of the mechanism to replace the current ones with, also I am trying to wrap my head around how it is supposed to work so that I can fix it properly. Anybody care to enlighten me. Thanks
Reclining Seat Mechanism
All Studebaker Parts that are still available, and there are a LOT, can only be found at Studebaker Vendors, they can be found at: studebakervendors.com Yes all Reclining Seat parts are available.
You need to get the Book form or CD ROM form '59 to '64 Studebaker Shop manual and Body and Chassis Parts Catalogs also available at Studebaker Vendors then you will understand what you are dealing with.
By the way, never GREASE the Sliding Gear, or Circumferential Gear (Housing) they work on friction and will slip.StudeRich
Originally posted by semaj4712 View PostThanks again guys, this was a really easy fix, really easy fix, after replacing the broken pieces and putting it all back together it worked like a charm.
