View Full Version : Crankshaft hub stupid question
Lark Parker
07-17-2007, 09:54 PM
The holes in the crankshaft hub are not evenly spaced so that the flexure plate or flywheel will fit on "only one way".
Since the A/T converter can fit on the the flexure plate in any position and (except for the bolt holes) the stick shift flywheel is symmetrical ---
Why did Studebaker make the crankshaft hub holes in a unique configuration?
There surely must be an incorrect statement in the above. (?)
Lark Parker aka Trim Trader
07-18-2007, 02:28 AM
Do I get 20 points for a correct guess? Or a free ride in a new 2007 Studebaker SUV?
I think it is part of the anti-vibration system. Since the rubber anti-vibration pads are also off-set AND they are each different, one has more offset than the other but they do fit the special hole pattern that the dampener, the hub and the pads all share.
Also by having only one way to install the vibration dampener, it's balance can be kept correct.
Maybe they balanced the dampener as an assy. with the crank and the Converters or Flywheels were individually balanced so there is no need to "key" them to the crank!
I think this requires a more technical explanation from the "World's Most Wonderful Studebaker Mechanic"!!!LOL!:D:D
Studebakers Northwest
Ferndale, WA
Lark Parker
07-18-2007, 07:59 AM
Since I have no idea as to the correct answer, and your answer does sound plausible, I will advance you ten points for having your hand up first. [:p]
rusty nut garage
07-18-2007, 10:02 AM
No. the reason is that the timing marks are on the dampner, the offset holes guarantee the correct relationship with regards to cam timings.
57 SH (project)
60 Lark VIII 2dr sd (driver)
Lark Parker
07-18-2007, 10:38 AM
57 SH (project)
Nice try, but we are discussing the other end of the crankshaft.
However, I will award two points for the contribution.[:p]
rusty nut garage
07-18-2007, 11:18 AM
Thanks that probably the only 2 points I'll get all day. In fac if today is normal I'll be in the whole in points by the end of the day[^]
57 SH (project)
57 SH (project)
07-18-2007, 12:17 PM
Well, I won't even TRY for points on this. (Besides, I've switched to Pertronics units anyway!), but I DO have to say I kept wondering - thru the "answers" tendered so far, when they were gonna tie themselves to the question Mr. Parker had posed.[}:)]
My "guess" is this.... As far as a torque convertor goes, it doesn't matter. For a flywheel however, it would matter. Why? Might I quote the shop manual: "One hole is offset so that the flywheel can only be installed in one position, thereby maintaining the original balance of the crankshaft [assembly]. (brackets are mine, to point out the word "assembly" - which in my mind means they balanced the crank AND flywheel together.
As to the why on an automatic car??? One crank (as in replacement crankshaft) fits all instead of having cranks for auto-equipped cars and cranks for standard shift cars. Unlike AMC did with some of their 6cyl engines.[8]
Miscreant adrift in
the BerStuda Triangle
Lark Parker
07-18-2007, 12:41 PM
Miscreant adrift in
[img]
You are awarded 3.14159265358979 points for addressing the specific question and, further, looking it up in the shop manual. (I wish I'd thought of that.) [:p]
Perhaps those of us that really care for our Studebakers need to have the whole assembly balanced whenever we replace a flywheel? [^]
We need someone to go first. Fifty points will be awarded. :D
07-18-2007, 12:49 PM
I confess, I've never worried beyond having a crank OR flywheel balanced seperately (and, yes, I know there's advantages for doing them together - or so I've been told)
I wish now that I'd had Pete's "new" crank and intended flywheel balanced together, but for both items, I never foresaw them "coming together" to ultimately serve in the truck!
The engine was built as a spare for whatever and the flywheel is the one that's served in Pete for years. It's one that came out of a truck I parted out years ago, so it's not served with it's "partner" crankshaft in a long time.:(
Miscreant adrift in
07-18-2007, 02:39 PM
OK Lark, Biggs is right. I tend to go with my understanding of the NOMENCLATURE used in the question, ie: "Crankshaft Hub" so naturally I went off on vibration dampeners, because the common AND "Studebaker" term for the front vibration dampener mounting hub is "Crankshaft HUB"! I never heard of the rear crank flange being called a "HUB". So of course I thought you were comparing the front of the crank to the rear, and I did forget that the rear bolt pattern IS NOT symmetrical just like I knew the front one is. :(
Bottom line, I misunderstood completely, all because of that little word "HUB"! ...DAH! :(
Looks like I get a -20 points...darn!
Well, hey whatda ya expect!..."Crankshaft Hub Stupid Question" ya got a "Stupid" answer! LOL! :D
Ferndale, WA
Lark Parker
07-18-2007, 04:01 PM
Ferndale, WA
I can remain blameless and almost immaculate because I included my standard disclaimer about "incorrect statement in the above". And I did spend some time mentioning the flywheel, flex plate and A/T converter. :D
DEEPNHOCK
07-18-2007, 06:24 PM
And I thought it all depended on what color anti freeze was installed...
Lark Parker... You are a devious sort this week[}:)]
Lark Parker
07-18-2007, 10:36 PM
Interesting you should mention antifreeze.:)
It's very possible that the Canadian and Los Angeles Studebakers used a different color from the pink that was correct for the South Bend cars.
07-18-2007, 10:52 PM
How terrible!![xx(] You mean they didn't use SP tested & approved anti-freeze?:(
Well Lark; you find us one car of each of the 3 with the ORIGINAL fluid and we'll take samples and test it, that's easy! :D
Ferndale, WA
dictator27
07-18-2007, 10:55 PM
There is another side to this. It used to be that timing marks were on the flywheel because there wasn't any vibration damper. To keep the timing mark in the right place the flywheel could only be mounted in one position.
Terry
DEEPNHOCK
07-18-2007, 11:23 PM
Terry,
You are dating yourself, but you are spot on as to what the various industries did about marking flywheels and timing marks...
Terry
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Gmail.com
Brooklet, Georgia
'61 Hawk (project)
