View Full Version : locking the doors
Michidan
07-17-2007, 10:49 AM
I've had this 52 for 10 years now but have never driven it. Putting the doors all back together, trying to find the pieces, etc...
How do the door locks work anyway? I have never known. Do you pull up to open the door - push down to lock...something like that?
Or is the only way to lock / unlock the door using the key on the outside?
Dan
52 hardtop
www.studebakerhardtop.com
Guido
07-17-2007, 12:24 PM
Dan,
From the tone of your post, I resume you are speaking of the INSIDE door handles? While I do not have any specific '52 car knowledge, I suspect they are just like the trucks of that era where you can push the inside handle to the locked position.
Gary
http://thumb14.webshots.net/t/53/453/1/21/36/2964121360097493054pVJTFL_th.jpghttp://thumb14.webshots.net/t/57/757/2/88/4/2023288040097493054SEKowB_th.jpghttp://thumb14.webshots.net/t/18/19/8/37/21/2050837210097493054IYBJJL_th.jpghttp://thumb14.webshots.net/t/59/559/1/43/57/2876143570097493054jKVhDw_th.jpghttp://thumb14.webshots.net/t/22/22/0/2/68/2589002680097493054ftBuBw_th.jpghttp://thumb14.webshots.net/t/28/28/8/30/30/2075830300097493054aSSlFv_th.jpghttp://thumb14.webshots.net/t/59/459/2/23/86/2067223860097493054YoeGMx_th.jpghttp://thumb14.webshots.net/t/28/28/5/18/33/2537518330097493054OgEKcN_th.jpg
Studebaker horse drawn doctor’s buggy; Studebaker horse drawn “Izzer” buggy; 1946 M-16 fire truck; 1948 M-16 grain truck; 1949 2R17A fire truck; 1950 2R5 pickup; 1952 2R17A grain truck; 1952 Packard 200 4 door; 1955 E-38 grain truck; 1957 3E-40 flatbed; 1961 6E-28 grain truck; 1962 7E-13D 4x4 rack truck; 1962 7E-7 Champ pickup; 1962 GT Hawk 4 speed; 1963 8E-28 flatbed; 1964 Avanti R2 4 speed; 1964 Cruiser and various other "treasures" (including a 1959 IH B-120 4 wheel drive and numerous Oliver and Cockshutt tractors).
Michidan
07-17-2007, 12:39 PM
Yea, inside of 52 car.
The question stems from looking at the pile of parts that make up the door handle mechanism. The handle attaches to a swivel that seems to go either way. Then there is a long linkage assembly that pivots in the middle. Super complex thing-ama-bob that goes on the door at the rear. Plus the body striker plate. All of this is either rusty or greasy or both. Will take me a few weeks probably just to clean everything up.
When it does go back together I won't know if it works the way it was supposed to unless I know what it did in the first place! :D
It's tough assembly a Studebaker when you've never had or driven or even ridden in one before.
Dan
52 hardtop
07-17-2007, 12:42 PM
Dan; the inside door handles are supposed to hang almost straight down, so that pushing them forward locks the door, neutral is unlocked and pulling them back opens the door.
Studebakers Northwest
Ferndale, WA
MagikDraggin
07-17-2007, 02:07 PM
Ferndale, WA
Not meaning to hijack the thread, but does this mean the doors can be locked by pushing the handle forward and then shutting the door? The locking mechanism on my Hawk is extremely stiff when attempting to use the key to lock them....but they unlock just fine.
I'm always fearful of snapping the key off inside the tumbler some day.
Karl
http://img.photobucket.com/albums/v147/MagikDraggin/Other%20Stuff/IM000986-reduced.jpg?
1962 GT Hawk 4sp
07-17-2007, 02:46 PM
Karl; No that design ended in 1952 when they went to the new style handles, yours lock with the push up/down knobs from inside or the key from outside only. It is designed to help you NOT lock the keys inside! On four doors, it is still possible however, if you try!
Your '62 inside handles should return to "neutral" after opening a door, if they are weak returning, the "remote" has a worn spring. It is the little unit that the handles attache to.
Your "hard opening' problem is most likely the door latch needs lubrication or the linkage is binding inside the door, you also could help it by using lock lube in the cylinder keyhole.
Ferndale, WA
tyaughton
07-17-2007, 04:39 PM
Does that mean I'll be able to lock the 50 Convertible with the door handle? If/when I ever get it put back together?
Kewl.
j
Michidan
07-17-2007, 05:37 PM
Heh, that was my thinking too. Assuming I ever get this thing together, I am curious to know how it actually works. So you can lock the doors using the handle - sweet.
Dan
52 hardtop
mbstude
07-17-2007, 06:07 PM
quote:So you can lock the doors using the handle - sweet.
Actually, I think that when you close the door with it locked, when it shuts it will unluck. (Keeps you from locking your keys in the car. ;))
Or just do like I do with my truck:
When I rarely ever do lock the doors, I just leave the vent window unlocked. Reaching in to lock and unlock is no problem at all! But then again, who in their right mind would steal a bright orange Studebaker? [:o)]
FWIW, I hardly ever do lock them. Even at school the windows stay rolled down with the keys in the ignition. The joys of living in a small, rural town. :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Cruising the Proving Ground Test Track
http://i81.photobucket.com/albums/j209/mbstude/provingground2.jpg
Guido
07-17-2007, 11:02 PM
The keys are in the POR Looks Like Hell Hawk that is parked in my back yard as I type. I doubt anyone will want to go far sitting on a plastic milk crate! :D
Decimal Dude (with a no interior Hawk)
55s
07-17-2007, 11:49 PM
The door locks are relatively simple.
(1)You cannot push the handle forward to lock the car.
(2)If the door is locked, pulling it towards you will unlock it.
(3)To lock, you must use either the key or push the button down.
(4)You cannot lock the car from the outside without the key, and the key mechanism needs to be working properly. Due to salt, no lubrication, and some of the metals used, lock mechanisms frequently do not work.
(5) You can take the lock apart and rekey fairly easily. I'm sure there are instructions somewhere on this site.
(6) The Shop Manual has lots of good pictures and instructions.
Paul
07-18-2007, 02:07 AM
Paul; that would depend on which poster you are trying to answer, the original poster Dan has a '52 that does lock with the handles, and Karl who has a '62 that locks with push buttons! Actually both have been answered.:)
Ferndale, WA
Michidan
07-18-2007, 09:02 AM
I think both have been answered too. If anyone is confused, 52 Studebakers do NOT have the door buttons like so many other cars have always had. Not sure when Stude went to this style.
Every other car I've ever had did have door lock buttons. But I've never had one this old. So i was really quite clueless about how the locks worked.
Dan
52 hardtop
rockne10
07-19-2007, 08:53 PM
In short, if you want to lock yourself out of a Studebaker, you must do so with the absolute intention of doing so.:D
