I realize a 700R4 transmission with an Edelbrock carburetor isn't a standard Studebaker setup. However, I know some have this configuration whether Studebaker or Chevy powered. So,...
I am hooking up the TV (throttle valve) cable. While there is an adapter available for proper TV cable geometry it strangely doesn't fit my carburetor (perhaps the Edlebrock carb. is for a Ford or Chrysler???).
Information is available on the internet showing how to make an adapter (angles, distances etc.). Every site list the full rotation of the throttle plates at 78 degrees. Using an angle gauge I'm getting a maximum of 71 degrees rotation. Has anyone experienced this with the Edelbrock carburetors? I have double checked that the secondary lock out and the choke fast idle are not interfering (both can reduce the angle of rotation). I have also ensured that the secondary stop has the throttle blades positioning the throttle plates perpendicular to the base.
The images posted show the: proper angles, the angle of the TV cable attachment point (wide shot and close-up).
The steel ruler bisects the center point of the throttle shaft and the center of the TV cable attachment point at 23 degrees. Not noted, but critical is the 1.125" distance from the throttle shaft center and the center of the TV cable attachment point. I spent hours to get these points aligned yet it seems negated because the throttle shaft rotation stops at 71 rather than 78 degrees rotation. That is 10% less rotation.
While I'm on the subject..., I have never seen information warning about the fast idle and secondary lock out affecting readings. More so, I have never seen anything written regarding setting idle speed. On injected cars the idle is typically corrected with an auxiliary air bleed. Thus, once set at the factory the throttle position (and TV cable position) stays set for life. But not so in a carbureted car which periodically needs adjustment.
Therefore if the 700R4 is to be properly set up it stands to reason that one should never go back and alter the idle because it will affect the transmission functionality. I'd say especially so with a 700R4 because should the throttle move off idle, even a marginal amount, the pressure is also suppose to increase immediately off its base pressure (pressure measured with the cable disconnected). This is a VERY critical setting!!!
Anyway, any input is appreciated.
Thanks, Tom
Thanks, Tom
