I have had a blast driving my 50 c cab around for the past few weeks. As you all know by now, the overdrive still isn't hooked up. My problem is this. I want the truck to be able to run highway speeds now and then. It was converted to 12V, leaving the OD inoperable. The pickup has 488 gears and tops out at around 42mph. I have a number of choices here.
1. Find a 12V solenoid and all the other switches to make the OD work.
2. Rig up a 6V battery system just for the OD.
3. Go back to 6V completely.
4. Change out the ring and pinion.
5. Swap out the entire rear end.
All of these choices will require $ and time. Just need some input as to which way would be the easiest and cheapest to do.
