Just spoke to a friend of mine who says that when you install radial tires on a car originally designed for bias tires, you have to set the camber to a positive value. I have a 1962 Hawk has anyone had any experience with this?
Front end alignment with radial tires
Front Axle / Front Suspension: Front end alignment with radial tires
Laisez le bon temps roulez avec un StudebakerTags: None
Alignment
Ideally,yes. But your Hawk is a king pin set up that won't adjust to to any noticeable positive amount.
I'm sure a bunch of members will jump in and assure you the alignment won't be a problem. You do need to get proper wheels to handle the stress forces created by radial tires. Good luck.
All this does is allow the top, "back" angle of the king pin angle to help self center and give a better "feeling" of the road at the steering wheel.
Also, as mentioned above either "0" or 1/2 degree negitive for the camber .
This would be for a street going car. The values get larger/same direction for a more race oriented car.
This may be difficult to do with the limitations in the Stude suspension parts.
