I had my 1955 Studebaker Coupe automatic transmission rebuilt . The cost was $2,899.57. This was more than the quote. The car backed out of their shop fine but took several tries to get into drive, park, neutral, low, park then finally into drive. The owner just said to move gear shift around a little. After 200 miles the shifting is much worse.
My Question is:
Should the transmission shop have repaired the linkage when they had the transmission apart?
Should I take it back and cause a problem?
Should I take it somewhere else to get fixed?
The job has a one year warranty. Does the linkage come under the transmission warranty?
Will transmission have to be taken out again to fix linkage?
At this point I don't know exactly how to approach the problem. The car was hard to get out of park besides other transmission problems, when I took it in.
Larry
My Question is:
Larry
