Hello,
I have a '65 Daytona and have replaced the B-W automatic with a GM 700R4. Prior to removing the original B-W transmission I measured the output shaft centerline to the tunnel. I did this to ensure the 700R4's output shaft was following same trajectory as the B-W automatic when I set my transmission mount.
Yesterday I went "Pick A Parting" for a driveshaft. I found a shaft that is virtually the same difference in length as the B-W transmission is from the 700R4. Though it is customary to measure for a driveshaft with the wheels "up" I also measured for the wheels down as most of the cars in the yard have the wheels in a dropped position.
Anyway, the crux of my post is that the distance between the rear of the tailshaft housing and the center of the rear U-joint cap (customary measuring points) is greater with the wheels up (normal ride height) than it is with the wheels dropped downward. I had always assumed that the opposite was true. (See pictures)
1. The first picture with the yoke deeper in the tailshaft is with the wheels dropped downward.
2. The second picture with the yoke extended outward is with the wheels at normal ride height.
Is this common? Can anyone enlighten me???
Further, If I follow the rules of setting the yoke depth at 3/4" short of hitting the output shaft with the wheels up (normal ride height) I run the risk of the yoke banging into the transmission output shaft if I encounter a situation where the wheels drop fully moving the shaft inward.
So, basically I'm befuddled because the driveshaft yoke movement seems opposite of what I assumed normal. Likely 99% of the time the car will have the yoke depth overextended (I'm at about 1-1/4" and the general rule is no less than 3/4" no more than 1"). Yet if I don't have that shallow yoke depth I run the risk of damaging the drivetrain because the yoke can possibly hammer the transmission output shaft in situations where the wheels drop fully (though admittedly rare).
Any feedback would be appreciated. thanks, Tom
