hi,
I'm gathering all my chrome pieces for the dreaded (bank account-wise) trim to the chrome-plater.
Most of my 'tabs' (see photo) broke off, as usual I'm told, upon removal. One suggestion for repair I was given was to drill out the broken stud and tap for small screw. But I'm wondering if I couldn't simply put the retaining tabs (minus the spring-clips) back in place, and tack-weld them back in place? The trim strips seem to be magnetic so I assume they would weld ok, and a quick tap with my MIG welder on each spot (that used to be a mushroom head rivet) would hold the clip in place, wouldn't it? I would do this BEFORE rechroming, so any bubbling of chrome from the heat is not an issue, and if I just "1,2,3" spot-weld it quickly, it seems I shouldn't distort the fairly thick and heavy trim strip. Has anyone tried this? Or is the drill and tap method the wisest method to use? Attached photo shows one of the door strips, but have same issue on all four (two at quarter window and both doors of course). Also, I don't think it should cause a problem at plating, I'd just have chrome plated retainer clips; all they do is hold the spring clips in place so shouldn't be an issue......
Thoughts or advice? Thanks!
