The Tremec TKO 600 that was installed into my 63 Resto-mod avanti came from Liberty Gear but they do not sell the speedometer adapters. The TKO 600 I am using is a GM application mounted to a Stude GM pattern bellhousing for the Borg Warner T-10. My stock SW speedometer was a 140 MPH factory speedometer that was refurbished with a 160 MPH faceplate. I know the number of teeth on the speedometer gear is a function of wheel diameter (26.85" for 215/70/15) and my rear end ratio which is 3.73.
Does anyone who has done the Tremec 5 speed conversion in an avanti know where I can order a speedometer cable adapter to connect speedometer to Tremec trans and request the correct number of gear teeth to get close to the right speed reading?
Thanks, John
P.S. - the rebirth of R2386 is about 1 month away now from coming home. She will be at South Bend International Meet for everyone to see.
Thanks, John
