In an article about Wrigley Field they had this photo. Can anyone identify the car on the left?
Wrigley Field, Can anyone identify this car?
Originally posted by klifton1 View PostThe one in the photo is a 37, but Deepnhocks photo is a 1938.
Klif
BTW, the 38 Standard is my favorite fat fendered Ford. The grill comes back into the hood sides similar to a 37 Stude.Dick Steinkamp
Bellingham, WA
Originally posted by klifton1 View PostI see lake plugs on that coupe. Whats on the sides of the hood and under the hood ?
Klif
The sides of the hood are the OEM louvers and stainless trim. The sun glare makes them look more dominate than they are.
Power is a modestly rebuilt 305 SBC tied to the original drive line, totally rebuilt. It would run on cruise control all day on the expressway at legal speeds. The weak link was the brakes. They stopped it but not like a modern car.
I always wanted an Avanti and found one at the right price so ----!!
Thanks for asking, The 39 is still a fond memory. Bob
I just grabbed a pic off Google... It was labeled wrong.
Y'all know I am never wrong about stuff
Originally posted by klifton1 View PostThe one in the photo is a 37, but Deepnhock's photo is a 1938.
KlifHTIH (Hope The Info Helps)
Its a 37 Ford Flatback sedan, they also made a humpback. Could also of had the V-8 60hp a smaller version of the regular flathead. Remember my daddy saying that they had to back up steep hills.
1937
CID Bore " Stroke " Comp. HP@RPM Torque@RPM Model
221 3.0625 3.750 6.2:1 85@3800 78
(1)
221 3.0625 3.750 7.5:1 94@3800 78
(2)
136 2.60 3.20 60@ 74
(1) Aluminum heads (2) Cast iron heads
221CID uses Stromberg 97, 136CID uses Stronberg 81 carb.
A new, smaller, V8 enters production. Called the V8-60, it gives 70 mph speeds and the best gas mileage of any Ford built before. It is designed for European laws that tax on displacement, as well as British laws that tax on bore size. Important to racing history because it will break the Offy's hold on midget racing. The V8-60 has a gear type oil pump driven off the crank timing gear. The V8-60's heads use 17 studs, not the 21 studs of the larger V8. For this year only, the little V8 has sheet metal sides on the block. The V8-85 gets a larger, relocated water pump, larger insert main bearings, and new cast alloy-steel domed pistons.
[QUOTE=clonelark;646705]A new, smaller, V8 enters production. Called the V8-60, it gives 70 mph speeds and the best gas mileage of any Ford built before. It is designed for European laws that tax on displacement, as well as British laws that tax on bore size. Important to racing history because it will break the Offy's hold on midget racing. The V8-60 has a gear type oil pump driven off the crank timing gear. The V8-60's heads use 17 studs, not the 21 studs of the larger V8. For this year only, the little V8 has sheet metal sides on the block. The V8-85 gets a larger, relocated water pump, larger insert main bearings, and new cast alloy-steel domed pistons.
"During WWII I recall riding in the back seat of my uncle's 1937 V8 60. We always carried a jug of water because it over-heated, constantly. My dad commented that he didn't like it nearly as much as our 1936 Chevy."
http://www.youtube.com/watch?v=_67ra...eature=related[/QUOTE)]"Growing old is mandatory, but growing up is optional." author unknown
