I've read every thread I can find about reverse opening hoods for the 53 & 54 C/K looking for the best ideas on how to convert mine. I saw Jerry Forrester's version and I like it but he indicated it was challenging as I'm sure any attempt will be challenging. So, if anyone has a good idea I would like to see it. If I'm going to do it now is the time.
Reverse Opening Hood For 53 & 54 C/K
Jerry Forrester's setup was about the easiest to so, because the parts are all available from the bone-yard, for the most part.
The other one setup I see one picture of from a long time ago is pretty much a barn door hinge screwed to the front valence sheet metal.
If you want it for custom reasons, I'd go with Jerry's idea, which I have seen a couple of and played with them personally.
If all you want is the safety aspect, the drilling the latch pin is a $2 solution that takes an hour to accomplish.
Here's a link to some pic's I took of Jerry's hood setup.
http://rides.webshots.com/album/551570762qnQxPN
JeffHTIH (Hope The Info Helps)
FWIW, My 1984 Saab 900 had a reverse opening hood that seems to operate a lot like Jerry's. I'm wondering if the Saab mechanism can be adapted to fit the C/K...
I ended up with another design which was also more expensive and complicated than most CASOs would attempt. Next time I'm in that garage, I'll get a photo.
Bottom line, the Stude hood is large, a complicated shape and difficult to move the hinge to the front, but it is worth the effort.
jack vinesPackardV8
Hey, why not have a SIDE-opening hood, like an old Buick? http://www.srbymichael.com/manufacturers/carolina/carolina.shtml Then you can even take it off completely to REALLY get a good shot at the engine!
John
Originally posted by DEEPNHOCK View PostJerry Forrester's setup was about the easiest to so, because the parts are all available from the bone-yard, for the most part.
JeffJerry Forrester
Forrester's Chrome
Douglasville, Georgia
Originally posted by Johnnywiffer View PostHey, why not have a SIDE-opening hood, like an old Buick? http://www.srbymichael.com/manufacturers/carolina/carolina.shtml Then you can even take it off completely to REALLY get a good shot at the engine!
John
I've been at the shop all day so I'm just now reviewing everyone's comments. I appreciate everything that has been shared but I'm still undecided. It will be about two more weeks before I'm at the go or no-go point so I'm still open for ideas and/or comments.
jack vines[/QUOTE]
Jack, it is comments like this that cause me to want to proceed. I guess what I would like to find out now is an estimate of how much time would be involved in making the conversion.
Originally posted by Baker54 View PostHi Jerry, as I said, I have reviewed the photos of your system. If you were to do it again how many hours would it take?Jerry Forrester
Forrester's Chrome
