View Full Version : Adhere hood insulator
jbwhttail
07-11-2007, 09:50 PM
I am having problems keeping the rear half of my hood insulator adhered to the hood. On hot days it droops loose, push it back up and it stays for awhile then same thing again.
What works and where do I get it?
Last time I do this,I promise
bige
07-11-2007, 10:10 PM
3m Super Trim Adhesive, pad in my Avanti up for a couple years now and it definitely gats hot in there(G)
ErnieR
http://i146.photobucket.com/albums/r241/AvantiR2/track.jpg
GTtim
07-11-2007, 10:13 PM
ditto
Tim K.
'64 R2 GT Hawk
07-11-2007, 10:32 PM
I comes in a spray can. Spray both the pad and the hood. Let it tack up several minutes before you put the pad in place.
Skip Lackie
07-12-2007, 08:12 AM
ErnieR
Make sure you get the SUPER Trim Adhesive. 3M makes three different strengths. I believe the number of the one you want is 8090.
Skip Lackie
Washington DC
jbwhttail
07-16-2007, 03:27 PM
I got it and will tape off the area and get started tonite... thanks guys!
53k
07-16-2007, 09:13 PM
And be careful. Once it touches the other surface, you won't be moving it again. After installing one I realized why so many of them are crooked in factory installations:).
Museum R-4 engine
GTtim
07-16-2007, 10:38 PM
Cover the engine bay and fenders with a sheet, the stuff splatters like crazy.
Tim K.
'64 R2 GT Hawk
jbwhttail
07-17-2007, 12:00 AM
I can assure you the car will be protected, can I get a Trojan that large:D
jbwhttail
07-17-2007, 08:42 PM
I attached the insulater tonite, I used a plastic drop cloth tho protect the car along with masking tape. I followed the directions on the can and all appears well.
One thing I did that seemed to help alot was to cut a piece of the plastic(clear) slightly bigger than the pad and placing it over the glued pad. We raised the pad located it properly and then gently moved the plastic back a couple inches at a time. This allowed us to rub out any air pockets as we moved from the cowl back to the front grill. Straight as an arrow in perfect position. Hope it helps someone in the future.
OK I lied....I'll do it again for the "right" car, I love the chase.....
mbstude
07-17-2007, 08:44 PM
Good job, Joe. :)
Sorry to hear that you guys won't be coming down for the GA Meet. But with gas prices, I don't blame you. See ya at the next one!
quote:OK I lied....I'll do it again for the "right" car, I love the chase.....
Found a Super Lark? ;)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Cruising the Proving Ground Test Track
http://i81.photobucket.com/albums/j209/mbstude/provingground2.jpg
jbwhttail
07-18-2007, 03:49 PM
Matt keep an eye and an ear out for that "right car" for me
