I have some transmissions and other heavy items I can bring to South Bend if anyone is interested. I don't want to load them if no one is interested.
A good Flightomatic out of a '63 Cruiser. This was in my Daughter's car and I replaced it with a 200R. Was working fine when removed. $150.
What I think is a '56 Flightomatic, has yellow tag with 32553 stamped on it. Has the bell housing and converter with it also. Converter has 95098-FT stamped on it so I know the converter is a standard type, not Avanti. It is supposed to be good but I can't guarantee it, just what the guy told me I bought it from a couple years ago. $100.
A T-10 four speed with the GM bolt pattern wide ratio (2.54 first gear). This is excellent as I rebuilt it to run in the Tomato several years ago and only ran it two seasons. I took it out when I built a close ratio for the Tomato. $600.
A T-10 four speed with Studebaker bolt pattern also wide ratio. Appears to be good but can't guarantee. We can remove the shift cover for you to look at if interested. $350.
Same as above only GM bolt pattern. $350.
A T-86 Overdrive for '51 through '57. Appears to be good and can remove top cover to look at if want. $125.
A T-86 transmission, no OD. $50.
A T-96? (only has four bolt top cover), no OD. $30.
289 crank stroke 1/4" (3.875") Been turned .020" on mains and .010" on rods and should be turned .010" more. $275.
289 long nose crank .010"-.010". $175.
259 long nose crank standard $50.
259 short nose crank standard $40.
Truck Block standard full flow 3E19342. Had small crack at left side drain plug and has been repaired. $150.
259 '60 block V457318 bored .125" sonic checked $125.
Four speed truck transmission. Not mine but fellow says it is good. Checked the gears by shifting and feels good. Has emergency brake attached. $125 (He will be there if you want to talk to him)
Any Edelbrock carburetor; Manual or electric choke, 500 or 600 cfm, new or reman. If interested in a specific one, email me (tedharbit@aol.com) and I'll send you the price.
Aluminum radiator made to replace stock on '51 V-8, excellent condition. $225.
