I have my Delco window distributor all cleaned up and ready to drop in but in reading the Lark service manual on installation it says to install without the rotor as it will not clear the firewall with it on. What kind of clearance will I have on a '55 C-body? I'm doing a trans overhaul and new clutch soon, would that be a good time to do the swap? I can raise or lower the rear of the engine as needed.
Delco window distributor into C/K?
All they are saying is that the flat round disc of a rotor will hit the firewall when you slide in the distributor.
Take the rotor off, slip in the distributor, and put the rotor right back on.
Should only slow you down by about one minute.
HTIH
JeffHTIH (Hope The Info Helps)
Originally posted by DEEPNHOCK View PostAll they are saying is that the flat round disc of a rotor will hit the firewall when you slide in the distributor.
HTIH
In a C or K body the window distributor will be slightly closer to the firewall. With old soft motor mounts the distributor can hit the firewall under acceleration and break the cap and rotor. But then I've done that once or twice in Studes that did not have the window distributor.
Probably the biggest reason the Hawks didn't use the window distributor at the time the Larks did is because the Hawks had a tachometer sending unit under their distributor cap and there wasn't a sender to fit the window distributor.Restorations by Skip Towne
Originally posted by Dwain G. View PostIn a C or K body the window distributor will be slightly closer to the firewall. With old soft motor mounts the distributor can hit the firewall under acceleration and break the cap and rotor. But then I've done that once or twice in Studes that did not have the window distributor.
Originally posted by Dwain G. View PostProbably the biggest reason the Hawks didn't use the window distributor at the time the Larks did is because the Hawks had a tachometer sending unit under their distributor cap and there wasn't a sender to fit the window distributor.
"With old soft motor mounts the distributor can hit the firewall under acceleration and break the cap and rotor. But then I've done that once or twice in Studes that did not have the window distributor."
Yup! Be it weak motor mounts or a rear ender, we should all carry a spare rotor.
