I am restoring a 50 Studebaker Champion and am in the process of installing new "cat whiskers" in the doors which sweep the glass on its way up or down. Attaching the new material to the inside of the door was easy as replacement clips were available. The cat whisker that attaches to the inside glass frame is another matter. Studebaker used some form of a stapler to attach the cat whisker to the metal frame. Although I had a heavy duty stapler, that old window frame just laughed when I tried to staple through it. Does anyone have an alternative suggestion that might work? I considered rivets but was concerned that the rivet head would scratch the glass. Someone suggested glue but this doesn't sound like a permanent solution to me. Any suggestions on what might work or what worked for you? Any help would be greatly appreciated.
Installing new "cat whiskers" in doors
Vicki, I asked the same question on Truck Talk:
http://www.network54.com/Forum/23885...indow+Whiskers
I plan to look at the problem again and try to use the clips on that side also. Just need to drill the same size holes like the other side. The only issue would be a clearance problem so I'll have to check for that. I'm a bit away from working on that for now...1948 M15A-20 Flatbed Truck Rescue
See rescue progress here on this blog:
http://studem15a-20.blogspot.com/
A friend of mine with a '54 Kaiser had a similar situation just recently. Some of the catwhiskers were attached the same way. On the advice of other Kaiser owners, he used 3M Black Super Weatherstrip Adhesive and glued them on. When he first told me his plans, I suggested trying one first and letting it dry........and then see how well it really held.
Well, he brought it by a few days ago -- and let me tell you, that catwhisker is ON THERE, and ain't coming off anytime soon! I was amazed at how that adhesive held, and I put a lot of force on it trying to pull it off. Would not have believed it.
If you try this, clean all surfaces really good with Oil/Wax/Grease Remover or something similar.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
