View Full Version : Powershift Transmission Rear Spline Play
studebaker-R2-4-me
07-08-2007, 12:52 PM
I have a substantial pool of transmission fluid on my garage floor. The drip is constant and appear to be coming from the rear transmission seal. I've pulled the drive shaft and found the rear spline has a great deal of play with the drive shaft removed.
How much play would be normal?
Allen
1964 GT Hawk soon to be R2 Clone
tbredehoft
07-08-2007, 01:58 PM
Sounds like you need two items, a rear bushing and a rear seal. The bushing will take care of the 'wobble', the seal will keep the oil in. A new seal will work until it gets worn from the wobble. Maybe instead of a bushing you need a rear spline piece. it shouldn't wobble on the splines.
Before you do anything, wait for someone to correct me.
Tom Bredehoft
'53 Commander Coupe
'60 Lark VI
'05 Legacy Ltd Wagon
N8N
07-08-2007, 02:53 PM
If I'm understanding things correctly, a little wobble with the slip yoke removed is not necessarily bad, but if the slip yoke itself wobbles, you may need a new rear bushing. Also carefully inspect the slip yoke, if there's a noticeable groove or pitting in it that may take out your new seal.
studebaker-R2-4-me
07-08-2007, 05:17 PM
With the drive shaft installed there is no play in the rear yoke; therefore I do not think the rear bushing needs servicing. The rear seal is a definite for replacement. The drive shaft slip yoke is not pitted and appears in fine shape, not perfect but relatively good shape . It was my impression from the previous owner the transmission was rebuilt some 10,000 miles ago.
My concern was with the drive shaft slip yoke removed how much play would be normal on the spline that stick out of the transmission?
ROADRACELARK
07-08-2007, 05:47 PM
Alan,
What Nate says, and, shiney up the yoke with some fine corocus cloth, put a new seal in, lube up the yoke before install, you should be good to go. The tail shaft without the yoke is ok to be loose...needs to be snug with the yoke installed. Hope this helps. :)
Dan Miller
Atlanta, GA
studebaker-R2-4-me
07-08-2007, 06:50 PM
Thanks, I clean up the drive shaft slip yoke and install the new seal.
Allen
