View Full Version : Part id needed
T-CAB
04-10-2012, 09:59 PM
I found this wiring harness in my stash of old stude parts. Does anyone no what it would fit. I was thinking either a turn signal harness or a power window harness. Any idea would be appreciated. If it worth anything I will but it on Ebay.
Thanks.
T-cab
14750
(S)
04-11-2012, 01:54 AM
Heavy looking wires like that may be a window motor, but not like a wagonaire. What guage is the wire? Looks very Avanti. It may also be a powershift back up light harness but does not look like a regular stude to me.... good luck.
T-CAB
04-11-2012, 08:26 AM
Thanks. I never thhought of an Avanti transmission. I do not know the gauge, but they are much heavier than the wires used on my '64 steering column harness. There is a red, black, green and yellow wire attached to the switch. The other end has a female connector for the yellow, red and green. In addition all four wires connect to a larger connector that has two male and two female.
This may not even be Stude, but it did come from a former Stude dealer.
T-cab
8E45E
04-11-2012, 08:30 AM
Very probable, Mike; neutral safety/backup light switch for a Powershift transmission.
53k
04-11-2012, 08:35 AM
T-cab
It's not for a Powershift. I think it is the switch mounted in the tail gate of a Wagonaire with the power window. It's been a long time since I had to replace mine, but it rings a bell in my fuzzy memory.
(S)
04-11-2012, 12:07 PM
I checked a power tailgate motor and is has the same color of wires, single male bullet ends on them. They are heavy so it probably is one or the other.
stude1964
04-12-2012, 09:35 AM
It's for the wagon power rear window & includes the switch.
