View Full Version : Sound and heat deadening
kmac530
04-07-2012, 11:53 AM
I did a search and I could only find one thread on Dynamat. There were some suggestions there on eBond or something like that.
I was curious if there was more options nowdays that you guys are liking?
I need both heat and sound deadening. What is the best bang for my buck?
04-07-2012, 12:23 PM
Take a look at Lizard Skin. I"ve not used it (yet), but it sounds good.
Corvanti
04-07-2012, 01:01 PM
i used this on the avanti:
http://www.ebay.com/itm/SALE-1-4-4X6-MIGHTYMATT-FOIL-ON-BOTH-SIDES-INSULATION-/130676142821?pt=Motors_Car_Truck_Parts_Accessories&hash=item1e6ce7b2e5
i was very happy with the results, and the price was much lower than dynamat... :)
they also have a thicker mat now, and for you, Kelly, motorcycle stuff!!!
p.s. - i don't know this guy, and your shipping costs will probably be higher (NC to CA)...
like Mr. K said, lizard skin is great also... but a little pricey for me. ;)
kmac530
04-07-2012, 01:47 PM
Bob, I like the simplicity of the Lizard Skin, but MAN is it pricey. You need a special gun to spray it on at about $100.00, then there are 2 different formulas you need to get the sound deadening and one for the heat protection. You have to stack them on top of each other to get both effects. A 2 gallon pale of each cost over $150.00 ea. and they only cover about 40-45 sq ft. No where near enough to do inside of doors, fire wall, floor, back wall, and inside the roof. So about $400.00 still wont cover and they only come in 2 Gal pales so now to get enough to cover or even more than I need is another $300.00...I am not spending $700.00.
scott.rodgers
04-07-2012, 03:01 PM
I've used a lot of Dynamat through the years. It does a great job but it's expensive. I buy the bulk packs through Ebay. Eastwood now makes a similar product that's cheaper than Dynamat but I haven't tried it.
MChance
04-07-2012, 03:27 PM
I too like the "Lizard skin" method but agree on the pricey part. I ended up searching for a similar alternative. And found Hy-tech a spinoff comany from NASA. uses pretty much the same stuff as Lizard skin but WAY less expensive.
http://www.hytechsales.com/prodsc.html
unimogjohn
04-07-2012, 04:46 PM
I just put this in my Avanti. http://www.b-quiet.com/extreme.html Installation was easy, just cut, lay down and shape to fit. It really sticks, once it is down, it is down forever. I recommend it. They have two different grades, I used the less expensive one. Today I drove the car for the first time with the mat and carpet in. I could not believe the difference. Really quiet. I was amazed. It took the 50 sq foot roll to do the floors. Here is a pic.
bezhawk
04-07-2012, 05:17 PM
I have used Lizard Skin, and was happy with the results. I also used a closed cell dense foam under the carpet. I got mine from Loews, in the carpet section......listed as anti fatigue mat.
okc63avanti
04-07-2012, 07:43 PM
Michael Myer used 3M rubberized undercoating under all surfaces on my body (inside fender wells & under floor pan) to help with sound deading. Then we used Lizard Skin to reduce heat and sound inside the body by spraying on inside of firewall, floor pan and inside the doors. Of course this was all done before anything else had been installed inside the interior.
johnod
04-07-2012, 08:00 PM
Here are 3 products i found and ordered, in my recent search, all at much better prices than the name brand stuff.
hope that helps.
Started with this (fatmat) today, seems good, and way cheaper than dynamat.
http://www.fatmat.com/
Check the test results link on this site.
http://www.lobucrod.com/
Warren Webb
04-07-2012, 10:15 PM
Kelly, why dont you & I get together in June & go to the L.A. Roadsters show in Pomona. They have tons of vendors there showing all kinds of newest & greatest stuff plus with the swap meet area it makes an all day thing. Fathers day weekend usually. I took Joy once & she couldn't handle even half of it.
oltrknut
04-07-2012, 10:48 PM
Hey you guys. Google e-dead that should send you to a firm in florida, cant remember the name, it is the same product as dynamat at about 20% of the cost. It comes with no name on it available in multple thicknesses, I do an entire car for a couple hundred dollars. I will look up the name on monday if you dont find it. Allen
kmac530
04-08-2012, 01:21 AM
I have found FatMat and RattleTrap that both seem pretty close to DM and about half price. Th eDead stuff is only for sound not heat and this truck gets HOT inside. The eDead is also not 20% the price, it is about 50% the price. It goes for 2 bucks per sq ft. and DM goes for about 4 buck p/sq ft. The FatMat is only $1.50 p/sq ft/ Best deal so far I have found.
http://cgi.ebay.com/100-Sq-Ft-Sound-deadener-Fatmat-no-logo-Dynamat-Roller-?cmd=ViewItem&hash=item3f070755f8&item=270700860920&pt=LH_DefaultDomain_0
52 Ragtop
04-08-2012, 05:36 AM
I bought some FatMat off eBay for my Avanti, 100 sq ft for about $140 including shipping. It is identical to Dynamat. as others have said at half the cost or better.
Jim
cultural infidel
04-08-2012, 08:41 AM
Read alot about this one on the HAMB. Probably going to go this route when its time.
mdelapp
04-08-2012, 08:44 AM
Has anyone considered using Ice and Water Shield? It comes in rolls at Home Depot or Loew's etc. It has backing paper to strip and adesive to adhere. It will not support moisture ( I guess that is why it is speicifed on so many roof valleys and edges)
One or two layrs should do terrific job and I would suspect a whole lot less expensive.
WR Grace manufacturers a product called Bituthane.
Here's a link
http://www.homedepot.com/buy/building-materials-roofing-gutters-roofing-felt-underlayment/w-r-grace-36-in-x-75-ft-grace-ice-water-shield-171695.html
sasquatch
04-08-2012, 11:00 AM
I used Rattle Trap from Fat Mat, 80mil. Got it from Amazon with free shipping (at that time). Went down easy and sticks like crazy. Got rid of all that tinny noise; much quieter. Used the entire 50 sq ft roll in my cab. The truck is still hot in the summer but it takes longer to get there now.
kmac530
04-08-2012, 11:53 AM
The lobucrod EZ cool stuff looks nice for cooling, but again, no sound deadening. The eDead is sound deadening but no insulation. You could do a layer of each, but then you are back to Dynamat prices...vicious circle.
Mike De, I have a bunch of left over Grace Vycor which is almost exactly the same stuff as their Ice & Water, it is butyl rubber water barrier with pressure sensitive adhesive and a smooth vinyl face on the outside. I plan on using that in all of the depressions in the floor as an initial sound deadener and to smooth out the floor a bit before I put whatever foil backed butyl stuff I find, I think I am leaning toward the FatMat.. Use my Butyl in the low spots, a layer of FatMat everywhere, then maybe a layer just on the floor of that lobucrod EZ mat. man that woul probably be really nice, quiet and cool ehh.
kmac530
04-08-2012, 12:50 PM
That sounds good. We do have a few things going on in June, CO visit and a One day Assembly, so I need to verify, but I think that week is ok, I will pencil you in for now and let you know. Maybe Mike Lloyd will want to go along also. That would be a fun day.
btw, my wife hates those long car show days too. She does not mind walking around theTemecula Rod run for an hour, but then she is done.
52hawk
04-08-2012, 12:56 PM
I felt kinda poor,or cheap? when I did mine-I used black roofing felt paper.
