I need a choke heat tube (from manifold to the carb) for a Stromberg ww - anybody have one?
Looking for a choke heat tube
I don't, but you should specify whether it's a top, or bottom mounted choke.Bez Auto Alchemy
Should be easy to make one. Original was copper plated steel, flared with a brass nut that screwed to the choke. The other end slipped over the smaller tube. The other tube on the manifold connects to the air horn of the carburetor with a rubber hose for filtered air.Bez Auto Alchemy
I have one (or 10)...
You might have to bend it a little...
Send me a PM with your address...
I owe you one...
JeffHTIH (Hope The Info Helps)
