Lark 4 Speed
  • Transmission / Overdrive: Lark 4 Speed
    I've been considering a 4 speed for my 62 Daytona and have a T10 cornered. What bolt pattern is required for the bellhousing, Ford or GM? It has a T86o/d.
    Thanks in advance,
    Kim
    The T86 in Larks is/was the Ford pattern bellhousing. Use your existing bellhousing with a '62-64 T10.
    jack vines
      I think I remember reading on a post that the Chevy pattern would work, all you need to do was enlarge 2 of the holes a bit and it would line right up. Perhaps you can check archives on this. Good luck. Or what Jack said.
        The "Ford" bolt pattern Studebaker T-10 is actually '63 - '64. The '61 - '62 Studebaker T-10 is the "Chevrolet" bolt pattern. I once changed a 3 speed '63 Daytona Wagon over using a '63 4 speed. I'd already had the drive shaft lengthened the required amount, so with cutting the floorboard for the shifter and swapping the transmissions, I was ready to drive it after about 2 hours work. Well, I was younger then... Fortunately the Wagon was a straight 3 speed - no overdrive - so the 3.31 rear end was perfect for the swap.
          My 62 Hawk GT has the chevy pattern and the Hurst shifter.
            As others have stated, the 61-62 4-speeds had the chevy bolt pattern, but since you have a T-86 you'll want the ford bolt pattern (63-64) T-10 that way you can use the bell housing you have. Another thing to check is the gear ratio. They were available with a 2.20 1st gear (close ratio) and a 2.54 1st gear (wide ratio), personally I would avoid the 2.20 1st gear.
            Joe
            1962 Daytona
            1964 Cruiser
            And a few others
              So, Did the 62 4 Speed trans use the chevy bolt pattern and the T86 o/d tans use the ford? Can I in fact elongate holes to make chevy work? Excuse me dumbness, but why should I avoid the 2:20 first gear ratio? Will the input shaft work with my stock clutch disc? I also hope that with the 3:31 gear it will a good swap as well. I should probably leave well enough alone as the o/d and gear combo works very well, but want the novelty of the 4 speed and hope not to loose top gear rpms.
              Thanks for the guidance,
              Kim
                Kim
                The 61-62 4-speeds are the 'odd-balls' with the Chevy bolt pattern. The 3-speeds, o/d's, and 63-64 4 speeds use the ford bolt pattern. I don't know the exact measurements but the Chevy pattern is wider, from side to side the bolt holes are about 3 inches farther apart than the ford bolt pattern. Nothing wrong with the close ratio 2.20 first gear trans just that it will give you a slighty slower take-off than the 2.54 first gear.
                Joe
                1962 Daytona
                1964 Cruiser
                And a few others
                  Kim
                  Not sure I understood your comment about not losing top gear rpms, but the gear ratio of 4th gear in a 4-speed is 1:1, just like the 1:1 ratio of 3rd in a 3-speed without OD. The OD reduces high-rear rpms by about 27%. If you are changing the rear axle ratio at the same time, some of that loss can be recovered.
                  Skip Lackie
