I recently purchased a 62 GT Hawk, 62V16543 and I am having trouble with the braking.
The brakes are well adjusted but not really stopping until a second push on the pedal. I have seen similar posts though I am not certain my symptoms are identical. Since I have never driven one of the C/K cars with HydroVac brakes, I am not sure what to expect. I have also not driven a power drum brake car for maybe twenty-five years though my recollection was a somewhat soft pedal but sensitive braking.
This car, even with the second push feels more like the manual brake '53-'54 C/K cars I had more than forty years ago. It stops well but with a lot of pedal effort. Basicly feels like the boost is not boosting.
I have gone through the shop manual HydroVac troubleshooting procedure. I am not sure how you tell all of the vacuum is gone by pumping the brakes but I pumped half a dozen times or so when called for in the procedure.
On the "pump then hold with the engine off and then starting the engine" procedure I could not discern the pedal falling away as the engine started. Is it possible that I was not sensitive enough or is it really obvious?
Who knows when any neetsfoot oil was last injected in to the HydroVac. The car was stored from '82-'02 and really only passed through a couple of owners since. No work is documented and few if any miles put on the car since '82. Anyway, I will give it a shot of neetsfoot oil today.
Any other insights as to determing the operation of the HydroVac would be helpful. I would be more than happy to replace the HydroVac with one of the newly manufactured units if that is truely the problem.
Thanks for any assistance.
Raymond
Raymond
