Hi All,
I recently purchased a 62 GT Hawk, 62V16543 and am having trouble figuring out what is tripping the 20 amp "Lights" switch CB. I have replaced all of the light bulbs with either the proper number or, in the case of the tail lighs, LED equiv. The tail lights and ond parking light had 1147 bulbs instead of the correct 1034. I also tried the correct 1034 bulbs in the tail light but they sure are dim. I see why a previous owner put in the 1147 bulbs.
The issue seems to be with the headlights as checking the car ammeter, with the engine NOT running, as I plug in each bulb shows bairly a blip with the tail lights or parking lights but nearly 10 amps for each headlight. The head lights are rated 55 watts (4.58 amps @ 12v) on low beam and 60 watts (5 amps) on high beam. With just the head light bulbs plugged in the ammeter shows maybe a 18-19 amp draw. With all bulbs plugged in and on low beam the ammeter shows just shy of 20 amps draw. On high beam the meter is just at 20 amps and the breaker trips within a few minutes which indicates that the meter is in agreement with the CB concerning the load.
I have no easy way to determine how accurate the ammeter is but I doubt that both the CB and the ammeter would be in error the same amount.
So, the question is: Is a 8-9 amp draw per headlight reasonable considering the rated wattage and if so, what is the workaround? If not reasonable what might be causing the increased draw? There is 0 amp draw with all of the bulb removed, suggesting that there is no short between the switch and the headlight bulbs.
Thanks in advance for any help.
Raymond
Raymond
