View Full Version : About a Studebaker website...
Nox
03-28-2012, 08:17 AM
I hope/think this is a Studebaker-related topic:
I've got a question about www.racingstudebakers website, it refuses to show up on my computer since a while ago. I thought it might be a computer-problem but I've tried other computers also. So: does anyone else have the same problem, & if so, what happened?
Nox.
shifter4
03-28-2012, 08:33 AM
The link that you put up is not complete. Try this :
http://racingstudebakers.com/foo/index.php
Bob Langer
03-28-2012, 08:39 AM
Or this. http://racingstudebakers.com/
Nox
03-28-2012, 08:41 AM
That didn't work either, it must be something wrong around here, it just says "error403" when I try it.
Maybe I should get in the car & drive out of the Amsterdam region & try somewhere else.
(Later, not now.)
Thanx for the possibility thou!
Nox.
03-28-2012, 09:38 AM
I just clicked on Bob's link and it popped right up.
52-fan
03-28-2012, 09:44 AM
Worked for me too although I have had problems in the past.
showbizkid
03-28-2012, 10:16 AM
403 is a "Forbidden" error. This indicates a fundamental access problem...the 403 error is equivalent to a blanket 'NO' by the Web server. It may be that Sonny is blocking IP addresses in your range, or outside a specified range.
SilverHawkDan
03-28-2012, 07:12 PM
Nox,
Sonny has had a real bad time with scammers and others messing up the web site. So he has the access settings real tight to prevent problems. So when I had this problem I e mailed Sonny and he gave me access. So I suggest you e mail Sonny at
racingstudebakers@pbtcomm.net
He will be glad to fix things up for you. I wondered where you went.
Dan
Nox
03-29-2012, 08:00 AM
Thanx a lot!
I'll be on to it as soon as I get hold on someone who understands this stuff AND can translate what my computers Swedish words might mean in English, I'm bad enough as it is with computer-languish in Swedish so I for sure will need some help with this...
Oh, it's gonna be GOOD to be back!
Nox.
Sonny
03-29-2012, 01:41 PM
Nox,
Dan
Yep, right on the money, Dan. In fact, most of the Asian Basin and ALL of eastern Europe has had to be banned! VERY bad "stuff" comes from those places! Only change, my email address is racingstude@pbtcomm.net. Special thanks to "shifter44" for the heads up. I'm workin' on getting Nox fixed up!
Nox
03-29-2012, 03:32 PM
This relives me a bit, I'm not that awfully happily impressed about the astern stuff either...
& I'm really happy that my problem is fixable!
Nox.
Nox
03-31-2012, 04:18 PM
Hey Sonny!
I received a E-mail that I should send one to racingstude@pbtcom.net, & so I did but it came back as a failure-notice, "impossible to send it to" or something like that it said.
Nox.
stupak
03-31-2012, 08:09 PM
Nox: It 'appears' that you didn't send to his complete address ......comm.net comm. not com. You might try that. stupak
Nox
04-01-2012, 10:25 AM
Guess what... While writing here it all worked out in the meantime.
Thanx alot for all the support & help!
Nox.
