View Full Version : Seat questions
kmac530
03-20-2012, 07:22 PM
Quick question folks, I just got a nice adjustable frame seat from Sasquatch, I am setting it up to mount it and I need to know if the original locating pins that stick out of the floor for the other type of seat I used to have need to be cut off for the new seat to fit and slide back and forth?
Or, can I leave them, as a just in case thing?
Second,
There are 4 small holes already in the floor that seem to line up with the new seat frame, I don't want to assume that those are correct, but since the 2 seats were options, maybe they are?
The 6 side mount bolts that bolt to the seat riser need to be drilled as far as I can tell, just want to verify. If those are the holes, does that position allow the seat to slide all the way back to the back wall?
Thanks folks.
kmac530
03-21-2012, 12:32 AM
Nobody has switched a Fixed frame to a sliding frame?
Dwain G.
03-21-2012, 09:55 AM
Kelly, check your emails and look for an attachment.
kmac530
03-21-2012, 10:21 AM
Thanks Dwain. As always you have great info. This place never ceases to amaze me with the knowledge, documantation, and willingness to share it.
