View Full Version : Interesting Brake Drum
rockinhawk
03-13-2012, 08:57 PM
I was working on the brakes on a 69 Dodge truck today. The rear drums were 11" finned. They looked so familiar that I pulled a Studebaker drum from my stash and compared the two. They are almost identical. After I got the shoes back on I slid the Hawk drum onto Truck axle. Perfect fit except the center hole was smaller than the Dodge. That leads me to beileve A Dodge truck drum could be used on a Studebaker. The lug pattern was the same untill sometime in the 80s. What do ya'll think? NT
1962larksedan
03-13-2012, 09:52 PM
The only issue I see here is since the Dodge drum would not 'center' on the axle flange; you may have some shaking/wheel lockup when you step on the brake pedal since the drum is effectively 'oblong' vs. the shoes.
tbirdtbird
03-13-2012, 11:48 PM
careful tightening of the lugnuts might work
rockinhawk
03-14-2012, 07:27 AM
The only issue I see here is since the Dodge drum would not 'center' on the axle flange; you may have some shaking/wheel lockup when you step on the brake pedal since the drum is effectively 'oblong' vs. the shoes.I thought about that too, but if the drum was pressed onto a Studebaker hub lug bolts,that would effectively center it. also it would be rather simple to have a bushing made to fillin the gap.
rusty nut garage
03-14-2012, 08:50 AM
They're are two aftermarket flanged axle kits that I'm familar with that are designed to replace the studebaker tapered axles. Both of them approach this issue of centering the drum a little differently. The FAIRBORN kit uses a bushing between the axle snub and the drum center (the preferred method and the prefered kit IMHO). the other kit uses 3 split bushings tha go between the wheel stud and the stud hole in the drum, a bit hoakey IMHO. This latter kit also has some fit issues with the bearing retainer. The only problem I see is what the availability of the drum your mentioning?
rockinhawk
03-14-2012, 04:21 PM
I'm not sure how long Dodge used that same drum. The local Bumper to Bumper Parts store said new ones were available for $125. I know an 82 Dodge used the same bolt pattern but don't know if the rest of the drum is the same or not.
I bought a new Dodge in 82 and wanted to put mudgrips on the back. I didn't want to dismount the new tires so I rounded up a couple of old Studebaker wheels and put the mud grips on them.
Later on I got an 87 Dodge and the bolt pattern had changed.
55 56 PREZ 4D
03-14-2012, 08:05 PM
My local NAPA didn't have Part# ND4401169 in stock [If that's the drum "Rockinhawk" was talking about. It's the only one on their site that was finned]
But could have them in within 2 or 3 days. $59.99 online.
WCP
03-15-2012, 11:49 AM
I sent you a PM.
