View Full Version : Hydrovac Mating Surfaces What do you think?
studebaker-R2-4-me
07-04-2007, 04:43 PM
After re-looking at the bottom mating surface on the newest hydrovac and JP's observation of some his cores being rejected. I want your opinion as to whether I should install this newest hydrovac.
Here is a picture of a really good mating surface http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0043.jpg
Here is a picture of the leaking hydrovac. You should notice the blurring of the ridges at 1:00 and 7:00 o'clock of the picture http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0034.jpg
This is a picture of the newest hydrovac which is suspect also.
http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0027.jpg
http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0031.jpg
http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0025.jpg
http://i122.photobucket.com/albums/o278/studebaker-r2-4-me/IMGP0024.jpg
I really don't like this newest hydrovac and think I may have problems getting it sealed.
1964 GT Hawk soon to be R2 Clone
JDP
07-04-2007, 05:14 PM
They don't look that bad. Make sure you are using soft, new, never used soft copper washers and crank them down real tight.
JDP/Maryland
64 Daytona HT/R2 clone
63 GT R2
63 Lark 2 door
62 Gt Hawk
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
studebaker-R2-4-me
07-04-2007, 05:51 PM
Thanks John, The pictures look better than in reality. The ridges are quite flattened at 8:00 oclock. I'll be painting my inner fender first then I'll give her a go with the two different sized copper washers I bought from SI as well!
GTtim
07-04-2007, 05:53 PM
It's hard to say from the photos, but they look as good or better than the one I got. I reiterate the above.
Tim K.
'64 R2 GT Hawk
sbca96
07-04-2007, 07:37 PM
It seems that it would be possible to mount the part in a lathe and
remove and then re-form the grooves. No??
Tom
gordr
07-05-2007, 01:17 AM
Tom, I expect those face grooves were made by some sort of piloted end mill. I wonder if a suitable mill could be made from a high-speed steel router bit? Cast iron is pretty easy to machine.
