I recently bought this 50 Champ for my daughter. As I began the process of getting the brakes operational, I discovered that the car isn't supposed to have 5 lug wheels. That will give you an indication of my level of Studebaker acumen!
Here's what I've found. The right rear drum fits properly on the axle taper and the seal appears to seat as it should. The left rear drum looks different from the other three in that the hub flange is on the inside of the drum. It doesn't fit properly as the drum contacts the backing plate before it seats on the axle. Looks like someone took a grinder to the outer edge of the shoes to try to create some clearance. The small end of the taper is 0.922".
The front end appears to have stock spindles, judging by the backing plate bolt pattern. The nut has been modified with a deeper slot for the cotter key as it won't go on as far as with the original, as described in another post.
I suppose I'm happy with the basic configuration for now, but I'd like to know what year and model these parts might be from so I can order the correct wheel cylinders and a proper drum for the left rear.
I also intend to replace the master cylinder and split the system.
Thanks!
Thanks!
