Will this hub cap fit your Studebaker??
  • Will this hub cap fit your Studebaker??
    If not what will it fit?? 15"
    Richard Quinn
    If I correctly ID it, can I have it??
    I'll guess a K10. Or a similar truck in the late 30's era.
      That looks like it was for the "Studebaker" SUV from a couple of years ago.
        You have some of the coolest stuff! I don't know what it is for, but I wish I had it. I would want it even if it was missing the hub cap you have.
          What's with the odd hole pattern? Sidemount?
          KURTRUK
            Looks like it could be for a K sereis truck. Are there any markings on it?
            Chris Dresbach
              Looks like someone's made an adapter for Studebaker dog dishes to a Ford F350 but, the bolt pattern is even wider than a set of Budds.
              Brad Johnson,
              '56 Sky Hawk in process
                You have it right Matthew, pretty good for a beginner! As far as getting the cap, it will be yours as soon as you have the truck to put it on. Incidentally there was also a K-10 Fast Transport panel truck.
                Richard Quinn
                  I get one right every now and then. For what it's worth, if you know of any K10's for sale, Phil Harris mentioned at dinner tonight that he is wanting one.
                    The holes at 4 and 8 o'clock differ from the ones at 10, 12, 2, and 6 o'clock. The sidemount appears to not use 4 and 8. Can you explain useage?
                    KURTRUK
                      Kurtruk; My guess they figured 4 lug nuts were enough to secure the cap.
                      Richard Quinn
