What are you guys using for a dependable mechanical V8 fuel pump?
What to do for a V8 fuel pump?
Tags: None
Small block Mopar Carter with two piece valve body.....modify the arm......presto-chango.....viola!
From Summit....just a couple of miles from you Matt.
Part # GM6270Last edited by bezhawk; 02-23-2012, 07:48 PM.Bez Auto Alchemy
JDP put a new airtex on my wagon, and just like the other airtex pumps I've had, it squirts oil out of the little vent hole. I must've went through half a dozen of them on my old '58. At least they had a warranty and replacing them every few months wasn't a big deal. But the wagon has power steering, making the pump a little tougher to get to.
Ted, I had forgotten that Phil sells the Mopar pumps converted to Studes. I'll call and have him bring one to York. Thanks! Problem solved.
Brad, Summit is about a half hour drive and I could probably find my way there with my eyes closed. I do plan on paying a visit after York to snag a set of these:
To confirm, Matthew: I put a Phil-Harris-modified MoPar pump on my vapor-lock-plagued 1964 Daytona Sedan last year and rerouted the fuel line (all steel, of course) outside the might-as-well-be-a-heat sink power steering pump. "No problem" since. BPWe've got to quit saying, "How stupid can you be?" Too many people are taking it as a challenge.
Matt, I've had my eye on a set of Rocket wheels just like you have shown for my Hawk. Has anyone had these on a Stude yet? I'm afraid of buying a set and then finding that they dont fit properly.sigpic
In the middle of MinneSTUDEa.
If they'll fit on my wagon, I think they'll fit a C/K. The rear on the wagon has less clearance than almost any other Stude, so I'm told.
They're from these guys: http://www.rocketracingwheels.com/
Anxious to see if those wheels fit--keep us posted. I'd been looking at American Racing Salt Flat Specials--but these are very similar and less expensive to boot.
I've been rebuilding the original Carter pumps using kits with modern materials as I don't like the quality of the later manufacture pumps. I've been buying used original pumps whenever I find one just to keep as spares. Bud
Originally posted by Bud View PostI've been rebuilding the original Carter pumps using kits with modern materials as I don't like the quality of the later manufacture pumps. I've been buying used original pumps whenever I find one just to keep as spares. BudPaul Johnson, Wild and Wonderful West Virginia.
I just put a new SI #1562992 fuel pump on my 64 259CI, cost $50 plus shipping, works great, no oil leaks.
34 Studebaker Street Rod (completed)
55 Speedster (in work)
63 Lark R2 (completed, 63K miles)
64 Daytona CNV (completed, 63K miles)
64 Avanti R2 (completed)
85 Avanti(blackout trim, 10K miles)
89 Avanti CNV (19K miles)
Originally posted by mbstude View PostJDP put a new airtex on my wagon, and just like the other airtex pumps I've had, it squirts oil out of the little vent hole. I must've went through half a dozen of them on my old '58. At least they had a warranty and replacing them every few months wasn't a big deal. But the wagon has power steering, making the pump a little tougher to get to.
I've looked at those wheels as a choice for my Avanti but I think they only come in a couple of offsets that may be questionable for my application. They will probably be a more favorable fit on your wagon as I'm going to quite wide tires. Just be sure to check your needs. They will look great!!!
Keep up the great work and keep posting.
Well done, Bob
