View Full Version : Engine: What did this engine come out of??
mjeansonne
02-23-2012, 06:23 PM
After using 12 quarts of oil for a 200 mile trip on International Drive Your Studebaker Day, I decided it was time to rebuild the engine in the Hawk.
The engine number is P104570. I believe the engine is a 289 non-Jet Thrust. What else can be told from the engine number? Such as year, model, etc.
Interestingly, it seems the engine has never been torn dowm. Everything is still standard and even the head gasket was steel. I hate to touch it, but we will have to bore the cylinders to .040 and turn the journals .010.
Thanks for the information.
Chucks Stude
02-23-2012, 06:39 PM
I used to carry 2-5qt. jugs of oil to go 300 miles. Turned out to be the end gaskets on the oil pan had crystallized. Uses a qt every 3000 miles now. I am even running 15-50 NAPA synthetic, with no problem. I didn't tear the engine down. It was as clean as a whistle inside.
StudeDave57
02-23-2012, 06:46 PM
I was just checking out the list myself~
http://www.studebakerdriversclub.com/V8EngineID.asp
Yours looks to be a '63 289... :D
Mine turned out to be '57 259.
02-23-2012, 06:52 PM
Your answer is here:
It MAY be a '63 Lark/Hawk 289, is it a full flow Filter engine?
It would not be an R Series Engine unless it starts with R, RS, JT, or JTS.
feralcat0_0
02-23-2012, 07:39 PM
Gentelmen; Hope its OK to ask this question. What would engine # L-894 be. This is from the build sheet for my '58 Packard Starlight Coupe. It doesn't fit as I see it on the list provided. Thank you Bob Fish
02-23-2012, 08:18 PM
It says that '58 Packard 289 (Studebaker) Engines START at L-101, so that is what it is, the 893rd. one Assembled.
You have a '58 Packard Starlight HARDTOP, not a Coupe.
feralcat0_0
02-23-2012, 08:30 PM
Thank you StudeRich. Bob Fish
