I have a Lionel Stone aluminum intake manifold that almost, but not quite fits. The best lineup of the bolt holes leaves the passenger side about .070 high at the rear tapering to flush at the front when the driver's side is flush. Can I have a machine shop re plane the passenger side, leaving the rear as it is and taper to the front with the front being about .070 lower? I'm not a machinist so I don't know if this will foul up the driver's side. I posted on the racing Studebaker site as well, so hopefully, some one will be able to help. I found a link to deepnhock polishing one.
Lionel Stone Intake Manifold
Fuel System: Lionel Stone Intake Manifold
78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279Tags: None
The valley cover is off. I was just placing the manifold directly on the heads to check for fit. The stock manifold fits perfectly, of course.
this problem is virtually identical to the one Nate posted about in 2005. Nate, did you ever get this resolved?
Alan,
the problem that I have with this manifold is that apparently two different jigs were used for the various machining operations, and they are apparently out of sync with each other. The bolt holes are drilled correctly WRT the ports, but if you bolt it down there's gaps at opposite corners of the mating surfaces. I can set it down square on the engine, but then the bolt holes don't line up. I'm sure someone with a milling machine and a handy Stude engine to mock it up on could fix it easily, but I don't have a milling machine :/
Alternately I could just slot the bolt holes and bolt it down, but I'm worried that then there would be a "step" in the wrong direction in the intake ports; the ports of the intake are actually fairly close to gasket matched.
62 Daytona hardtop
78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
The first L Stone manifolds were done by a guy named Wally that worked with me at Garrett in the tooling dept. He built the jig that they still use to this day to machine the manifolds. He ran a trade school and had students that did all the work. If they did not blow all the chips out of the fixture, the next manifold would come out caty-wompus. I welded up a number of manifolds for Stone that were rejected by customers.
It can be fixed. But at what cost? Without the manifold in front of me I can not say if a simple machine operation will do it or not. Shipping it to me in Calif. and back will cost more than what I would charge to weld it up for you, if it needs building up. Best to get with Jeff and see what he says. If he can't do it check back with me.
