View Full Version : Need Overhaul Kit for aTransmission
Anne F. Goodman
06-29-2007, 06:21 PM
Where can I find an overhaul kit for 1957 Flightomatic Transmission Borg warner. Gaskets seals Disc's? And about how much are they?
Thank You
Mabel 1949 Champion
1957 Silverhawk
1955 Champion 4Dr.Regal
Gus 1958 Transtar
Fresno,Ca
http://i122.photobucket.com/albums/o269/nw3anne/Mabel.jpg?t=1165475035http://i122.photobucket.com/albums/o269/nw3anne/xmasannecopy.jpg
glen
06-29-2007, 06:58 PM
I don't know who has kits, Anne, but Studebaker Intl, will sell
you almost everything you need...I went online and saw gaskets
@ $7.00 each and more....they may be able to give you a discout
or rebuild price... http://www.studebaker-intl.com/ at least worth
a try. Maybe another member will have a better lead....
PS: if you use the "search" engine at the top of the page and
look for "flight o matic".... there is a lot of previous talk
http://i57.photobucket.com/albums/g204/glen_05/Daytonalurkinintheshortgrass.jpg
1964 Daytona
glen Brose
Tumbleweed Flats, AZ
rockne10
06-29-2007, 09:16 PM
I got a kit for my DG200 (1951) from Fatsco. That was a number of years ago and almost $400. I'm sure they would have kits and bands available.
http://www.fatsco.com/
Brad Johnson
http://www.4wheelz.net/virtual/images/rockne/1928_rockne03_f820_th.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
dynolou2
06-30-2007, 01:44 AM
To identify which model that your car has, the lenght of the main case: small case is 9 7/8 medeimum is 10 7/32. do not count bellhousing or extension housing. Northwest Transmission Parts in Winchester Ohio should be able to help you out. Phone # ! 800 327 1955 Small case 1953-1957 master OH kit $ 131.45 1958-1967 $122.98 medimum case 1955-1967 122.98. A master kit contains gaskets lip seals o rings front and rear seals, clutches and steels. Prices may have changed a little as only brocure I could find is dated 5/01/03. Good Luck Lou Cote[8D]
Kdancy
06-30-2007, 09:18 AM
Link to Northwestern -
http://northwesttransmissionparts.com/
06-30-2007, 09:37 PM
We can determine exactly which variant of FOM you have if there's any traces of paint on the ID tag of the tranny. They used different color ID tags thru the years to indicate which model trans was employed.
Miscreant adrift in
the BerStuda Triangle
Rosstude
06-30-2007, 10:30 PM
I purchased a “kit” and 1 front bushing, and 1 center support bushing from Fairborn. About $280 for the stuff I needed. If you have a 57 short tail FOM, you could do a first gear start conversion very easy and inexpensively, I can provide details on what worked for me.
[img=left]http://i52.photobucket.com/albums/g27/Rosstude/OldWorld2005002.jpg[/img=left]
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
wagonairedriver
07-01-2007, 10:47 PM
check partsamerica.com I bought a overhaul master kit for my '64 flightomatic on sale for $35.99! It normally was only about $100. It contain all the clutch packs, sealing rings, gaskets. I think if you don't have any hard parts which are bad, this one should do it. The part number is 752071. Don'y know if it would be the same for your year, so please verify.
Kdancy
07-02-2007, 06:16 AM
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=PIO&MfrPartNumber=752071&PartType=646&PTSet=A
Link
wagonairedriver
07-02-2007, 11:22 AM
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
Ross, I have a 64 Daytona and a 65 cruiser, both with FOMs and would love to have first gear start. Any info would be very much appreciated. thanks, Kelly
