View Full Version : Can't get into gear!
mbstude
06-29-2007, 06:13 PM
Ok fellas, maybe you experts can chime in and figure out a way to fix my Scotsman. :(
My truck has a 3 on the tree.
I had to make a run to town, so I got in the truck, fired it up, put it in reverse and backed out of the carport. I went to pull it down into First, and it was in 3rd. For some reason, it will only go into 2nd and 3rd gear. Not sure what happened, but something broke!
I can pull 'up' (towards the steering wheel) on the shifter handle, but no matter how far I pull it, it will not go into 1st or reverse. I can reach down and pull the shifter shaft/tube (goes down into the floor alongside the steering column) up towards the steering wheel, and then drop the handle into 1st. I noticed that the long shaft appears to have dropped down maybe half an inch from what it should be.
Any clues fellas? What broke? How do I fix it?
Gotta get this thing fixed!
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
http://i81.photobucket.com/albums/j209/mbstude/00track.jpg
lstude
06-29-2007, 07:45 PM
Sorry that happened Matthew. I am sure someone will know what happened and how to fix it. I had a hard time getting my 52 into first at SB, but it starts off in second just fine.
I am going to put the transmission that I bought from Ted Harbit in tomorrow.
Leonard Shepherd
http://leonardshepherd.com/
http://i129.photobucket.com/albums/p235/lstude1/Mein64DaytonaatBradfieldssm2.jpghttp://i129.photobucket.com/albums/p235/lstude1/AlmostreadyforSB6-4.jpg
mbstude
06-29-2007, 07:49 PM
Good luck with the trans swap. Make sure the clutch and shifter linkages are all adjusted.
There's another '59 Scotsman PU at the shop, and nothing is left of it except for the cab, bed, and steering/shifter setup. If it's OK, I may just swap it all out. :) I think that would be a lot easier that fixing what's wrong with mine. [xx(] My steering box has too much slop anyways. I hope to get it all back going soon, this is my only ride!
I can start off in 2nd as well, but it does strain that little 6 a bit. Or, I can reach down and pull the shift tube up and then go into 1st or reverse. If I don't get it fixed, I'll be OK for a little while. [^]
Where's that weird wheel puller and black spray paint?... :D
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
mbstude
06-29-2007, 08:31 PM
Allright guys. I'm convinced that something has broke inside that little shifter 'gearbox' that mounts on top of the steering box.
The plan for now is to take the steering column/shifter setup out of the '59 Scotsman parts truck and put it in mine. (From one Scotsman to another!)
We shall see... :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
41 Frank
06-29-2007, 09:19 PM
Thats the way a frugal Scotsman (pun intended) would do it Matt.I think the South Bend gremlins have invaded both yours and Leonards vehicle.:D
We shall see... :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
mbstude
06-29-2007, 09:23 PM
quote:Thats the way a frugal Scotsman (pun intended) would do it Matt.
Lol! Pretty funny there Frank! And I completely agree! :D
I have to say though, after putting nearly 6000 miles on this truck, the only other problems I've had are a clogged gas line (my fault) and the points went out. I was long overdue for something to break. [:o)]
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Cruising the Proving Ground Test Track
http://i81.photobucket.com/albums/j209/mbstude/provingground2.jpg
41 Frank
06-29-2007, 09:30 PM
Should be a piece of cake geting it back on the road as you guys have a parts truck:)Considering how many times this truck has been shifted in he last 48 some years something has to give out at some point as it is so far beyond it engineered in life expectancy.
mbstude
06-29-2007, 09:37 PM
Yepp, parts cars are really the trick... :)
quote:Considering how many times this truck has been shifted in he last 48 some years something has to give out at some point as it is so far beyond it engineered in life expectancy.
Well, not quite that much. 56K original miles and the truck sat in a barn for 20 years before we got it. ;)[:o)]
How's the '41 coming?
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
41 Frank
06-29-2007, 09:54 PM
How's the 41 coming?
Haven't touched it since getting back from SB on Sunday Matt, had to do yard work etc. I intend to get serious about yanking the motor the week after next as next week I have to get my GT ready for the Goodguys show in Des moines Iowa.Its just a matter of 8-10 bolts to get front clip off, after that the motor mounts and she is ready to come out, all lines and hardware have been removed allready.
cabrina
06-29-2007, 10:21 PM
Hi Matthew,
Had a 49 pick-up that used to lock-up when shifting maybe a couple of times a year. I'd pry off the plug on the control shift box, take a big screwdriver and manually ratchet the gear teeth around till they engaged in the proper pattern.
Hope you get the Scotsman operating properly again. May it's just light headed from cruising around the proving ground track!
Cabrina Dieters
Murfreesboro TN
Karl
06-30-2007, 12:53 AM
This won't fix your shifter. But might put a smile on your face.
http://i117.photobucket.com/albums/o50/twnchgr/PICT1204.jpg
Thought you might like this.:D
63 Twin Supercharged Avanti
64 Avanti R3w/NOS
88LSC Avanti 350 Supercharged w/NOS
Mark57
06-30-2007, 01:25 AM
[quote]Originally posted by Karl
Now that's what I like to see... a Stude Truck holding up a couple of Avanti's[:0][}:)]:D
Mark
57 Transtar
mbstude
06-30-2007, 11:20 AM
Thanks Karl! My truck actually looks a little shiny there! :D
Who's that kid standing off to the far right? :)
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Karl
06-30-2007, 04:09 PM
No idea? Some one e-mailed me the picture. Thought it was kinda neat seeing you truck at the front of the pack.[8D]
64 Avanti R3w/NOS
mbstude
06-30-2007, 07:50 PM
I agree Karl and Mark. Nothing like my old truck holding up a bunch of Avantis. ;)[:o)]
Good news! My uncle and I got the shifter problem fixed. The little pot-metal collar/clamp thingy at the top of the steering column that holds the shifter tube/shaft was damaged. It's threaded where the shift tube goes in, and a little metal 'rod' is screwed into it. The tube fits over that, and it also serves as a pivot point for the shift handle. Well, where the rod screws into the collar was stripped out. We pulled the steering wheel off, took off that collar and replaced it with one from the parts truck. Put it all back together, and WOW, does it all work better! I guess that collar has been worn out for a while, and just now decided to let go!
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
Karl
06-30-2007, 11:47 PM
Good job....:D
64 Avanti R3w/NOS
ROADRACELARK
07-01-2007, 12:25 PM
Hi Matt,
I'd thought by now your grandad would have told you the results of trying to "power-shift" that 3-on-the-tree.[}:)] I guess you just have to learn the hard way.;) Just kidding.:D I know they do wear out.[xx(] South Bend was great!!!:D Glad ya'll got home safely. We'll see ya'll in August.
Dan (no room to talk) Miller
Atlanta, GA
mbstude
07-01-2007, 12:29 PM
quote:I'd thought by now your grandad would have told you the results of trying to "power-shift" that 3-on-the-tree.
Well, being it broke after I shook hands with Ted Harbit, maybe there's something to that, Dan... [8D]
Matthew Burnette
'59 Scotsman
'63 Daytona
Hazlehurst, GA
