View Full Version : Installing an Edelbrock
johnesmonde
09-10-2006, 10:57 PM
The Hawk currently has the original 4-barrel on the 289. Though the car is a 62, the engine is likely a 57 (block is blue). I want to install an Edelbrock 500. I know I have read info on this in this forum but don't know how to retrieve it. From what I remember reading, it should be a simple bolt on replacement to the existing manifold but may need a different air breather due to hood clearance issues. Can anyone give me advice and walk me through it?
Regards,
John
John Esmonde
Holland Landing, Ontario
Canada
'62 Hawk
'30 Chev Coach
whacker
09-10-2006, 11:51 PM
Well, you might start here:
http://www.studebakerdriversclub.com/sdc_forum/topic.asp?TOPIC_ID=5782
Or you could go to the top of this page and click on the search button (between "members" and "FAQ". Enter edelbrock in the search topic and scout around in the replys. After you read up a little, if you still have some questions, ask again.
DEEPNHOCK
09-11-2006, 08:48 AM
Your intake manifold will need to be modified slightly to have an AFB fit without using an adapter plate, or thick gasket stack (secondary throttle blade interference). The adapter plate can cause some hood clearance issues on early C/K's and on Avanti's. An electric choke AFB has been the most popular style for most swaps. The choke stove tube(s) will need to be moved to clear the secondary throttle linkage on the AFB. The throttle linkage will need a slight trim to clear the intake manifold runner. A custom air cleaner will be required, unless you modify yours to fit. Several people around the US sell modified intakes that are a bolt on deal. Some also sell installation kits to make it even easier, including blocking off the heat crossover passage to keep the carb cooler. Pricing for a modified intake has been running around $150 outright and $100 with a core manifold in exchange.
Hope the info helps.
http://i77.photobucket.com/albums/j54/deepnhock/Jeff%20Rice%20Studebaker%20Pictures/1937StudebakerCoupeExpressJeffRicee.jpg
DEEPNHOCK at Cox.net
Homeless[u]</u>
'61 Hawk (project)
valleyguy
09-11-2006, 08:49 AM
I did this conversion on my 58 hawk with the 289 engine. If I can do it, anyone can. The only clearance issue I
had was with the Edelbrock throttle linkage not clearing the intake manifold. I had no hood clearance problem with a new air cleaner.
To raise the new carb to allow the throttle linkage to clear the manifold, you'll need a spacer kit. (I also read that someone else did it without spacers by just
grinding off some material on the Edelbrock carb linkage)
I got my spacer kit at a speed shop that sells Edelbrock carbs;
the spacers are simply thin gaskets, (the kit has several metals ones and several made of gasket material), just use what you
need to raise the carb just enough.
My stock throttle linkage worked just fine with a little adjusting. I ran a manual choke cable from my dask to the new carb.
The instructions with my new Edelbrock carb were
very clear on which ports on the new carb to block off etc.
Hope this helps.
Rosstude
09-11-2006, 12:41 PM
Mr. DEEPINHOCK really sums it up. I will add that I used a 3/8” phenolic spacer from Trans-Dapt #2446, and it was just enough to clear the lower GM style trans linkage tab (which I may use later) and it also included the proper length studs and 2 gaskets. The speed shop I bought the spacer said the laminate style spacers can lead to the ears breaking off or warping on the aluminum carbs, if improperly tightened. I did cut the little choke tubes off top and bottom and JB welded them up, will not be needing them as I blocked off plates on the exhaust cross over, along with removing the flapper valve on the exhaust manifold.
So- I used a modified manifold I picked up off e-bay, an Edelbrock 1403, 500CFM carb, the 2446 trans-dapt spacer, and an install kit I got from Mr. Deepinhock which had the intake manifold gaskets and stainless steel exhaust cross over block off plates, and carb studs IIRC. Probley spent over $100 more on this conversion than having the original Carter WCFB professionally rebuilt would have cost, but I expect many years of trouble free service from a new carb.
Use the “search” feature found on the top of this page, or search the news group that can be found on google, you will find a wealth of info to glean from.
Ross.
Riverside, Ca.
1957 Provincial X2
1958 Transtar
1963 Lark. F.S.
johnesmonde
09-11-2006, 09:04 PM
Thank you to all! I now have a clue on how to use the 'search' function as well as some useful information. As always, positive and helpful response to a question that keeps non-mechanic Stude guys in the game.
Regards,
John
John Esmonde
Canada
'62 Hawk
'30 Chev Coach
