How do you tell if there is a need to replace the kingpins, bushings, etc.; or just the bushings, etc.? Thanks
King Pins - '64 Hawk
Jack up the front of the car and try to move the top of the wheel in and out. If you get more than 1/8 inch, it's time to disassemble the assembly and examine the king pin. Once disassembled (not a half hour task, more like half a day) degrease and examine the king pin itself. There are two diameters that are ground on it. if either of them show a significant wear pattern it time to replace the king pin. If not worn, just replace the bearing and the bushing. Its best to have a Chassis parts book to see exactly where each piece goes.
If you find that replacement of some of the components is in order, check on the pricing of the complete front suspension overhaul kit at our suppliers. I know the complete Avanti kit I purchased from SI came with a significant discount. Once you take it apart, you'll understand why you want to do it only once.
Bob
Originally posted by sweetolbob View PostIf you find that replacement of some of the components is in order, check on the pricing of the complete front suspension overhaul kit at our suppliers. I know the complete Avanti kit I purchased from SI came with a significant discount. Once you take it apart, you'll understand why you want to do it only once.
Bob--------------------------------------
