Many places on the net you can find part numbers for outer axle seals for DANA 44 flanged axles.
In some applications other than Studebakers,the outer seal is located on the axle between the wheel flange and the bearing. This allows the outer axle bearings to be lubed with the gear oil in the differential. Studebaker DOES NOT use gear oil for the outer bearings. You have to physically grease them.
A lot of times you will find NAPA 13165 , FEDERAL MOGUL 5131 or SKF 13165 listed as replacements for the old leather seal Studebaker used. This is NOT an acceptable seal. As you can see by the first picture it has a cone shape to it on the end that faces the axle flange/bearing. It sticks out so far it will not allow the bearing retainer to seat in the axle. DON'T WASTE YOUR MONEY ON THESE SEALS.
The seals you actually want to use are the CR 13157 or the SKF 13157. Also available is
seal # 533161 sold by Studebaker International. The other picture shows both of these seals side by side. Either one is fine. The SI seal cost $18.00 each. I got the CR 13157 for $12.oo each from my local FLAPS. Do not trust the cross references at the parts stores because most will come back to the SKF 13165 variations above. Use the CR/SKF 13157's or SI 3 533161 and save some $ and stress!
