Good Morning Guys I had great response from folks helping me find a good wire diagram Thanks fo that! Next up...Where the heck do some of those grounds attach. Obviously being "non meta" requires extra gtounds. I did not dis assemble this AVANTII so I am at a loss. First is the very large ground white wire that comes through the firewall. It has a large ring terminla on the end. Where does it attach? Second: running down the left frt inner fender in the are of the volt reg there is another group of grounding ring terminals where do they attach? Third: On the right side inner fender there is a long ground that runs way down front toward the horn. This has a ring terminal on also. Where does it belong??
While I have you reading I may as well stick this in. Where does the front left horn mount? The right front horn is in place(not by me) But the left one has to somehow deal with the battery position.
ALSO.. I need to replace the headlight and parking light three prong plugs. Does anyone have any used ones or can you tell me what I can substitute?
Thanks HAve a great Day
Toby in PA
Toby in PA
