View Full Version : Neoprene or Composition
bonehead007
06-25-2007, 09:19 AM
Now that I've got the Valve Covers painted & labeled , time to putem back on..The old gasket was the cork type, which I've scraped off...I'm aiming towards the neoprene but, do I use sealer on it and if so what type ?? Also is it better than the cork type ???
glen
06-25-2007, 09:43 AM
Here is a link from last month concerning the sealant
question and also goes into the types of materials to
use for the gaskets.....alittle
http://www.studebakerdriversclub.com/sdc_forum/topic.asp?TOPIC_ID=10168&SearchTerms=valve,cover,gaskets
Couldn't find a "thread" that covered likes/dislikes of types.........
Sorry about the "missing link" from the earlier post!
Hope this helps
http://i57.photobucket.com/albums/g204/glen_05/Daytonalurkinintheshortgrass.jpg
1964 Daytona
glen Brose
Tumbleweed Flats, AZ
64V-K7
06-25-2007, 03:17 PM
Neoprene is superior to cork. Use a light finger smear ( Not a bead) of red RTV to 'glue' the gasket to the cover. Get rid of any drips or squeege from under the gasket. Let it sit for a day. Make sure all the old gasket is gone from the flange on the head.
You can also opt to do a light smear on the flange also, but usually not necessary. Position gasket on head....... finger tight to 1/4 wrench turn, on the nuts. Let it sit for a day. Then torque to the factory spec, something like 10-12 inch lbs.
There's a lot of rational objection to using RTV on valve or pan gaskets, since a loose drop can get into your oiling system and wreak havoc. The same thing can happen with Permatex sealer though. Use your own judgement.
I've been using 3M #90 Contact adhesive on a lot of gaskets and find it very useful to hold things in place and seal also. A real gem with oil pan gaskets..
Bob Johnstone
http://www.studebaker-info.org/7168422/sig2.jpg
showbizkid
06-25-2007, 03:20 PM
Which reminds me... what do you use to torque to 12 inch-pounds? I've never seen a torque wrench that goes that low.
Clark in San Diego
'63 F2/Lark Standard
bonehead007
06-25-2007, 03:32 PM
Thanks forall of your advice...I'll use the neoprene gasket..As far as the torque, I have 2 wrenches that start at 0 & adjust accordingly to what you need..
Swifster
06-25-2007, 03:35 PM
Torque wrenches also come in inch pound measurements. Check out Sears.
Tom - Valrico, FL
1964 Studebaker Daytona - 289 4V, 4-Speed
http://i74.photobucket.com/albums/i280/Swifster/1965_Studebaker_Commander_front198x.jpg
bonehead007
06-25-2007, 03:55 PM
thats where I purchased mine...
BrianC
01-26-2009, 08:51 PM
One inch pound is equal to 0.08333 foot pound.
BrianC.
tbredehoft
01-26-2009, 09:00 PM
Valve cover screw torque rule of finger.
Apply wrench, use index finger, first joint, 2 1/2 inches from screw. pull till it hurts. Thats enough. It doesn't take much.
Tom Bredehoft
(Under Construction 571 hrs.)
'05 Legacy Ltd Wagon
All Indiana built cars
