View Full Version : differential carrier question please......
AKAchamptrucking
12-31-2011, 02:40 PM
Between a 331 flanged 44 and a 373 flanged 44 axle, is the carrier the same? Some carrier interchanges break at certain gear ratios. I have a flanged non TT 44 with 373 gears and I intend to use the TT carrier out of my 331 flanged if they are the same. Thanks in advance for the help.
12-31-2011, 02:55 PM
'59-'64 Chassis Parts Catalog Group 1004, 1004-6 CASE, Diff. Pg. 304.
Come on Rich. are telling me that you live in South Bend and do not have Manauls and Parts Catalogs? Lol!
:D
3.07-3.73 = Same Case
4.09-4.56 = Same Case
mbstude
12-31-2011, 03:03 PM
My granddad rebuilt the rear end in a '59 half ton pickup. He replaced the 4.27 gear set with a 3.54 gear set from a '60 Hawk rear end. Both were Dana 44s. I personally put over 10,000 miles on that rear end..
12-31-2011, 03:08 PM
Matt, he had to have taken the entire Carrier (Case) AND the Ring and Pinion out of the Housing and swapped it, because a 3.54 Ring Gear does not fit onto a 4.27 Case.
sweetolbob
12-31-2011, 03:10 PM
3:73 and down is the break point, So you are good Rich.
Bob
irish
12-31-2011, 03:14 PM
Don't forget the 3.92! 3.92-4.56 = Same Case
mbstude
12-31-2011, 03:17 PM
Could be Rich. I think he swapped over all of the internals.
AKAchamptrucking
12-31-2011, 04:19 PM
LOL Thanks Rich... I just posted the question since I was busy figuring I could tap the wealth of knowledge here. I bought the rear just to get the rest of the self adjusting BS I was missing and when I got it home and cleaned the tag it turns out to be a flanged 373 rear. It was in a 66 Cruised 4 door. I might O might just put a lock right in it and keep the 331 TT intact in case I break a rear end. I am guessing with that 373 rear and some small slicks I can easily be in the low 12's. That would be even more fun than it is now. I am just tight on coin,dang it.
12-31-2011, 04:29 PM
That is not in the book, not even in Jet Thrust Equipment Section because in '59-'64, a 3.92 ratio was not SUPPOSED to be available, but as we know special orders did happen. :)
The listing in the Showroom Dealers book maybe was not supposed to happen, but that does not mean that one or two were not ordered.
