View Full Version : 63 Avanti R2 hood clearance
ken-renda
12-31-2011, 10:27 AM
I'm about to cut out an SI hood insulator for the 63 R2 Avanti and would like to know the clearance between the top of the bonnet and the inside bottom of the hood immediately above the bonnet. Does the area above the bonnet have to be cutout? Ken, Deltaville, Va
sweetolbob
12-31-2011, 10:35 AM
Ken
Every one will be different based on quality of mounts etc. Just make a small column of modeling clay or similar material and close the hood on it. You can guarantee that it will stick to the air cleaner by taping a piece of wax paper to the hood.
Bob
ken-renda
12-31-2011, 05:22 PM
[QUOTE=sweetolbob;607268]Ken
Bob[/QUOTE
Do not have motor in car yet, what I'm trying to figure out is if I need to paint the underside of the hood in the area where the bonnet will possibly press against the hood and the underside of the hood is in bad shape in terms of preparing it for paint. Low profile motor mounts will be used.
12-31-2011, 05:49 PM
If you do not know, check the front Engine Mounts to be sure they are the short R3 Only Mounts.
ken-renda
12-31-2011, 07:19 PM
Have not ordered motor mounts yet, are the ones you refer to the same, or as low, as the SI low profile mounts, as that's what is on my list of parts yet to get. Ken
12-31-2011, 11:38 PM
Sorry Ken unless I ASSUME they are the same as mine, I can't be sure because my source is different.
JimsLeadCommander
01-01-2012, 10:11 PM
Oh, haystacks; sources are like horses: coy, devious, run away from trouble...
