View Full Version : 52 champion front fender won't come off
oliver
06-21-2007, 03:34 PM
- I'm pulling apart a 52 champion and have all visible bolts removed, and the air duct into the cockpit out (and the top bolt behind it). The fender's loose at the front but something is holding it around the hood hinge area on the firewall. Is there a weld there? Do I need to completely remove the hinge or is there a hidden bolt or something?
thanks for any info!
rockne10
06-21-2007, 08:51 PM
There are no welds. Have you removed the inner fender bolts to the firewall? And the hood springs? Antenna?
oliver
06-22-2007, 03:28 PM
Thanks - I'll check for any hidden inner fender bolts this weekend. Do you get to these inside the engine bay or through the wheelwell? I'm not saying anything else inside the wheelwell...
Hood springs are off, I'll check the antenna
rockne10
06-22-2007, 07:22 PM
I believe there are three inner fender to firewall, accessable through wheel well; also two from top with hood open on either side of hood spring.
Brad Johnson
http://www.4wheelz.net/virtual/images/rockne/1928_rockne03_f820_th.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
oliver
06-23-2007, 08:43 PM
> The front (lower) air deflector also has some going into the front of the lower part of the fender.
That was it - there was one at the bottom corner under the air dam. Thanks!
