View Full Version : Hood to body rubber seal
valleyguy
06-21-2007, 08:18 AM
I want to install the hood-to-body(cowl) rubber seal on ny
Hawk but I'm not sure of placement. the pic shows a dry fit.
should the seal be in this position (it would seem so from
the location of the old nail/screws) or should it lay
right up against the that edge to the right in the picture? Hopefully someone out there has the answer. Tks,
Joe D.
http://usera.imagecave.com/jadiggle/Studebaker174.jpg
A1956GoldenHawk
06-21-2007, 09:06 AM
Joe D.
IMHO, that repro'ed seal pictured above should have its longest portion laid up along the lower edge and of course, centered right-to-left to re-install those 2 drive screws an equal distance from the seal ends. BTW, wasn't there tri-angular shaped "anti-squeak" rubber pieces attached to the cowl ends just below the cowl seal ends in your pic.?
valleyguy
06-21-2007, 02:36 PM
A1956oldenHawk; I'm not following.... what do you mean by
the "longest portion" This seal, has a "fat part" which the hood
closes on and a lower channel for (I assume) channelling water
off. In it's present position, which way does it need to move? towards the windshield?, If I move it all the way towards the windhield, then the old screw holes will be exposed (you can see one of them peeking out below the seal); there were no triangular
shapes seals when I disassembled the car... Is this something
that I need to add? Tks,
Joe D.
rockne10
06-21-2007, 08:59 PM
Seal should be to forward edge; screws are centered through seal. I'm waiting to install mine until the final paint. The seal will hide the tape line between the body and engine compartment.
valleyguy
06-22-2007, 09:03 AM
Thanks rockne10, that's what I assumed based on the location
of the screws; I too planned to wait for final paint but I could also install it now; I painted
the firewall and little up on the cowl as you can see, which
sould make it easy to blend the paint. Do you have a
recommendation as to the type of adhesive? Tks,
rockne10
06-22-2007, 07:33 PM
I use 3M Super Weatherstrip adhesive (it's available in black or yellow). Follow the directions and you'll have a hard time moving it from its first position.
Brad Johnson
http://www.4wheelz.net/virtual/images/rockne/1928_rockne03_f820_th.jpg'33 Rockne 10, '51 Commander Starlight, '53 Commander Starlight
