Question: is there any way for me to run a column shift setup using a Stude steering column in my 1962 or will I need to 'bite the bullet' and go with a Lokar or similar floor shifter? Car was a 3spd/OD and I now have a TH350.
Best gear shifter for a TH350 in a 1962 Lark
Transmission / Overdrive: Best gear shifter for a TH350 in a 1962 Lark
"Do they all not, by mere virtue of having survived as relics of a bygone era, amass a level of respect perhaps not accorded to them when they were new?"Tags: None
I used a PowerShift setup in my '63 with a Chevy and a TH350
My car was a 4 speed car, however, so it had a bare column.
A PowerShift has the same quadrant as a TH350 and using one of these...
Kugel shift arm kit
...you can insure that the detents on the trans line up with the letters/numbers on the quadrant.
You could use the same Kugel device with a stock Stude automatic column. The only problem would be the letters/numbers on the column wouldn't match the P R N D 2 1 trans detents. I think Jeff H. has found a replacement for the Stude quadrant that will match. I just don't know what car it came out of.Dick Steinkamp
Bellingham, WA
The shifter lens with the letters (and the chrome bezel too) from a early Jeep Wagoneer will fit in any late Stude that uses the chrome bezel. Actually, the bezel will also fit the columns on earlier cars back to '53 as well.
Here is the Jeep part next to one from a Lark.
You need to find a older Wagoneer with column AT. I think '72 is the last year they used the same steering column upper parts as Studebaker. The '73 and later ones are completely different.
This is a '72 dash and steering wheel:
Problem is these are really hard to find, at least in MN and ND. Those wagoneers rusted out and were run into the ground long ago.
Jeff in ND
Originally posted by Dick Steinkamp View PostI used a PowerShift setup in my '63 with a Chevy and a TH350
Kugel shift arm kit
You could use the same Kugel device with a stock Stude automatic column. The only problem would be the letters/numbers on the column wouldn't match the P R N D 2 1 trans detents. I think Jeff H. has found a replacement for the Stude quadrant that will match. I just don't know what car it came out of.Candbstudebakers
Castro Valley,
California
Originally posted by candbstudebakers View PostSure like the dash and door panels in the 63, I bet they cost you a pretty penny? sure wish I had some for my 64 that nice.
I'll be down after Christmas. Your turn to buy lunch?Dick Steinkamp
Bellingham, WA
Originally posted by Baker54 View PostDoes anyone have/make the pieces to modify the floor shifter to work with a 2004R four speed automatic and make it look original?
If your question is to make the shifter in Dick S's car work with a 700R4/200R4 then I may have a solution.
Those shifters were also used in the Avanti and Avanti II's and the later II's came with 700/200 transmissions. The only difference I can see is the transparent shift indicator plate to show the gear selected. Those plates should be available from Nostalgic Motors in Wixom, Mi the large Avanti parts operation.
I have a spare shifter from a 700R4 Avanti II if you need a picture or other info.
BobLast edited by sweetolbob; 12-21-2011, 07:24 PM.
I have a spare shifter if you need a picture or other info.
BobPoet...Mystic...Soldier of Fortune. As always...self-absorbed, adversarial, cocky and in general a malcontent.
For what it's worth I used a mid 90's Camaro shifter and a mid to late 80's Cadillac console (cut down 2") with my 700R4. While not "Studebaker," it comes close to the time period considering these parts are 20-30 years newer. I really didn't want a swoopy, plastic formed console festooned with cup holders.
