View Full Version : Convertible Trans Removal
rayoung55
06-18-2007, 10:51 PM
Does anyone either know if it is possible or have any experience removing a 3 speed overdrive trans from a '60 Lark convertible without pulling the engine (259 V8)? It looks like the X member makes it darn near impossible to remove the trans from below the car.
Thanks!
Rob
JDP
06-18-2007, 11:11 PM
I have to believe that the trans will slide back enough to drop the front. Even the automatics in a Avanti will drop that way.
JDP/Maryland
64 Daytona HT/R2 clone
63 GT R2
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
fpstude
06-18-2007, 11:48 PM
I have removed the transmission from my '60 Lark without engine removal. It is not your combination. It is a Lark VI with a T 96 and overdrive. It was not easy. I had to remove the solenoid and governor prior to removal. Obviously the "X" frame is the problem. I had to fabricate higher transmission jack saddles, again because of the "X". It is a pain, but better than engine removal.
Perry
'23 Special Six,
'50 Business Champ,
'50 Starlight Champ,
'60 Lark droptop,
'63 GT
rayoung55
06-19-2007, 10:23 AM
Thanks guys. It may be some hassle, but it would sure beat having to pull the whole front end apart!!
Rob
52 Ragtop
06-23-2007, 06:46 PM
I just did a trans swap in my 62 ragtop, it was easier to pull the whole doghouse (about 16 bolts) and pull the enginf trans as an assy. It was out on Saturday, and back in Sunday. Would have had it running Sunday, but, I got the wrong P/S hoses. and had to wait on them.
Jim
