View Full Version : Voltage Regulator Problem?
terrymb
06-17-2007, 04:36 PM
Friday my 52 Commander had a completely dead new battery. Thought I left a light on or something. Charged it, ran the car 8 miles and 3 hours later, dead battery. Recharged the battery again and found 15A of current when the car is shut off. During trouble shooting I removed the BAT wire on the regulator, and the current draw disappeard. Ran the car again and noticed the car's amp meter register full charge (when the engine RPM was high enough.) Shut the car off and checked the current draw and found 15A. This time I whacked the regulator with a screwdriver handle (that's one of the uses of a screwdriver, right?) and the current dropped to 0. So, I suspect a bad regulator. Should I just replace it, or is there a way to fix the regulator and still be able to trust it. Car is still 6V.
Thanks!
1952 Commander Starlight
JDP
06-17-2007, 05:46 PM
You could try cleaning the points that might be sticking, but I'd swap it.
JDP/Maryland
64 Daytona HT/R2 clone
63 GT R2
63 Lark 2 door
62 Lark 2 door
60 Lark HT-60Hawk
59 3E truck
58 Starlight
52 & 53 Starliner
51 Commander
GTtim
06-17-2007, 08:43 PM
Take it apart and clean up the points. Check that they operate freely. Chances are, the regulator you have is going to be of better quality than the new one you'll get. (just MY opinion)
Tim K.
'64 R2 GT Hawk
terrymb
06-17-2007, 10:18 PM
The points on the bat side move freely but it looks like the top contact isn't flat but comes to a point. The points don't look very clean or shiney either. Could corrosion or a lack of flatness cause it to stick?
John Kirchhoff
06-18-2007, 12:26 PM
I'd use a point file to square up the contacts and keep an eye on things for a while.
jsallin
04-04-2008, 04:45 PM
I have a 54 pickup that the mechanic is telling me that he can't get the voltage regulator rebuilt, so has to find a new one, and hasn't been able to find one for the past 3 weeks. Does anyone know where to find a 12V voltage regulator that will work in my truck
Thanks for your help.
Josh
tbredehoft
04-04-2008, 05:10 PM
Check with Fifth Avenue Garage
http://www.fifthaveinternetgarage.com/parts/parts_counter_2.html
They have a solid state 'voltage regulator.'
[img=left]http://www.alink.com/personal/tbredehoft/Bothcars4.jpg[/img=left]
Tom Bredehoft
'53 Commander Coupe
'55 President (H6 Y6) State Sedan
(Under Construction) 164 hrs.
'05 Legacy Ltd Wagon
All Indiana built cars
bowss@aol.com
04-04-2008, 08:34 PM
Did you try "exciting the field" when you replaced the parts?
Flashback
04-04-2008, 10:24 PM
IF you don't have a shop manual, one would help. It has a good section on vcharging systems.
Tex in Alabama
53 Coupe
Tex E. Grier
